Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
How to Replace the top assembly
We recently broke the glass top of our range, bought a replacement top, and now are trying to figure out how to remove the old and install the new. Easier said than done at this point. There don't appear to be any screws holding the top in place. Yes, we opened the oven door and looked at the underside of the front lip of the top but can't see anything to unscrew. Can you offer any advise?
Many thanks.
    President:
  • Maytag Master
  • 2,651 Answers
What ir the model number your dealing with???? mer5755qas???? if so theres got to be screws holding downthe mian top to the unit it self, located under the front lip
Posted on Apr 05, 2008
Cracked rangestop glass assembly replace
These can be tricky, first remove everything you can from the glass top then very carefully using two small screwdrivers like tyre levers gently go around the outside & the glass top will lift off.
Apr 17, 2014 | GE Profile JB988 Electric Kitchen Range
Replace vent glass
It is easiest if you remove the door panel and passenger glass first. Once that is done it is much easier to remove the weather stripping, seal and vent window.
Dec 26, 2013 | 1998 Ford Expedition
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Glass top range is pitted and scratched from an abrasive cleanser. Can it be replaced. It is a whirlpool freestanding range about 2 years old
Yes, your glass top assembly on your range can be replace. Here is one link where you can get the part, http://www.apdepot.com/Products/PartsLookup2/IPLLookupFrames.aspx?Brand=WHIRLPOOL&ModelNo=GR399LXHS1&ImgID=EdI2&ImgFile=WTKIKKLL
It is a relatively easy job to replace the main top since the burners are not attached to the top assembly itself. Remove 2 or 3 screws on the front of the top and you can easily lift the entire top off of the range and replace it with the new top.
Apr 17, 2011 | Whirlpool GR399LXHS Electric Kitchen Range
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Ordered a replacement handle for oven door, trying to figure out
Open to the first hold area, where you set the door to broil. Lift off the hinge bars.
Jan 21, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Jan 02, 2009 | KitchenAid KESC308LSS Electric Kitchen...
Replacing smooth top
Have you purchased a new top yet? If you haven't, you can find it at repairclinic.com for about $270.00 (item #703866). Just type in your model number in the search index and you will find a pictorial part index for your range. The part isn't cheap, but it would potentially cost you twice as much to have a repair service replace it for you. If you still wish to pursue this repair, follow these simple instructions:
1. First of all, UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. Secondly, is the glass top still intact? I know it is broken, but is the glass completely busted apart, or is the top just cracked? If it busted, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cooktop. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the cooktop and leave the elements in place. Place the whole assembly face down on a soft surface (like some old towels, or a blanket) and remove the surface element assembly leaving all the elements wired together. Place the new cooktop face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place. Install the new cooktop back on the range and you are DONE.
5. If the wiring harness does NOT unplug, there are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
5. Lay the intact element assembly, with wires still connected, on top of the oven box handling the elements with care. they are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of.
7. Use care when screwing into the new cooktop. CAUTION: The scew holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Good luck and I hope this helps.
Feb 11, 2008 | Maytag MER5770 Electric Kitchen Range
Display light out - how can i replace it
If the display is out you probably need to replace whole range control. Also known as the clock assembly. Be sure to take model and serial number, also manufacturing number if it has one, when you go to get new part.
Nov 19, 2007 | Kitchen Ranges
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
133 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
