Question about Microsoft Wireless Notebook Optical Mouse VSBX300001
Microsoft Wireless Notebook Optical Mouse Not Connecting
The mouse itself used to work perfectly, but recently it stopped connecting. As i plug in the USB to the port the green light that says connect on the side does not light up anymore and the wireless mouse does absolutely nothing.I have replaced the battery, sometimes if I'm lucky a little text box pops up saying the USB malfuctioned.
Help aprreciated.
  • 6 more comments
  • stroodle May 21, 2008
    green light is on plug in and have reattached to port mouse is not working, I have used on other computer and it works fine, is there a driver available for this mouse? I may have lost the driver in this computer
  • Anonymous Jun 28, 2008
    same problem works on one computer not on the other.
  • Anonymous Jul 26, 2008
    yep, have the same problem. Mouse usb plug part is shot. this is the secocnd Microsoft notebook wireless optical mouse that has just gone bad. Seems like they have a life span then die. On both the green light just would not come on no matter what computer I plugged it into (usb port). I checked it on 3 computers gave up and bought another mouse and it worked fine.
  • 3samsam Oct 31, 2008
    my usb light is on , but the mouse optical light not on
  • zshockley Jan 07, 2009
    I have the exact same problem. It used to work perfectly and now it does not show the green connect light. I have replaced the battery twice and nothing. I have tried on several PC's and nothing.
  • jsimon77 Mar 15, 2009
    Like everyone else's, mine WAS working fine then just stopped (Vista Home x32) I tried a generic usb wired mouse and but get the same... not recognized... error.
    I downloaded the software from Microsoft, same issue.
    Before using it on the Vx32 machine, it had been working fine on my Vista Pr x64; but after trying this machine, it failed to be recognized on that machine too.
    I found a site that said to update the driver, repointing to the Windows\System32 directory (bug).
    That worked for my Vx64 machine and this wireless mouse has been working again w/no issues.
    However, I tried the same 'fix' on my Vx32 but it did not work for either the wireless and the wired mouse.
    It doesn't appear to be an issue with the specific mouse since neither mice... Seemed more like a general USB device/driver issue recognition (others have complained of the sudden inability to reconnect with USB harddrives, etc, but luckily for me, my camera still works yea).
    Anyone found the answer yet? Laptop does not have a ps2 so usb is my only choice!
  • kevin_s_hyat Nov 17, 2013
    I was having trouble connecting the Wireless Notebook Optical Mouse, Model: 1023
    Downloaded the software from microsoft here;http://www.microsoft.com/hardware/en-us/... went into the hardware monitor and right clicked the mouse which had a yellow icon, clicked properties, says the driver failed to initialize, clicked update driver, instead of searching online, I chose to install from drivers already on the computer. I chose the drivers that were installed with the software I downloaded from the link above. Unplugged the usb dongle, pressed the connect button on the dongle, pressed connect on the mouse. All is working now. Hope this helps
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Posted on Oct 01, 2009
Is your mouse is Microsoft Wireless notebook optical mouse model 1023?
re attach again you USB dongle to your mouse. then slowly remove your USB dongle from your mouse. If your Optical mouse lit. that's it. Insert the USB dongle to the USB port.
If not. Buy a new one.
Anyway, you'll have to change your mouse eventually.
Posted on Apr 14, 2008
I had the same problem. Check out this site http://support.microsoft.com/kb/838398 and see if your mouse is listed on the "applies to" section. If it is, follow the instructions - It worked for me, so hopefully, it will work for you, too!
Posted on Feb 07, 2009
    Problem Solver:
  • 4 Answers
This solution is for the model number 1023
If the wireless receiver is plugged in, the light is not on, the computer makes an unusual sound (dun dun dun!) when you plug in the receiver, if the red light under the mouse is working.
Open the device manager, for windows 7 press the start button and type "Device Manager"
Find the mouse on the list, it should have a yellow exclamation point next to it.
Right click the device
Click "Update Driver"
Click "Brows My Computer"
Click "Let me pick from a list of device drivers on my computer"
Un-check the box that says "Show compatible hardware"
On the left hand side, choose "Microsoft"
On the right hand side, choose "Microsoft USB Wireless Mouse (Mouse and Keyboard Center)"
Once the drivers have installed successfully, you will need to reboot your computer.
Once the computer has rebooted, if the mouse is still not responding, you might need to reconnect the receiver with the mouse by pressing the button on the receiver, then the button on the bottom of the mouse that says "connect"
This same process should work for most other windows operating system, you just need to figure out how to find the device manager. Usually in the control panel.
Posted on Mar 17, 2014
This may sound obvious but it happened to me so I'll share, the red light will still light up on the mouse even though the battery needs to be changed. I tried the other solutions before doing the obvious assuming the red light meant the battery was good, all fixed now though.
Posted on Aug 17, 2012
2 Suggested Answers
EvilDeadAsh
SOURCE: Microsoft Wireless Notebook Optical Mouse Not Connecting
I have the same mouse and I had to install the intellipoint 6.1 software that came with it, and it worked flawlessly. Then I sold a few of them that I had and mixed up the dongles in the sales and now none of them work. Trying to figure out if I can force a recognition or are they proprietary to only one mouse. Go to microsoft and see if the intellipoint 6.1 is a download.
Posted on May 31, 2008
The pointer on my microsoft wireless notebook optical mouse 3000 stopped working on the table next to my laptop. The pointer will work if I put the mouse on the laptop itself but when I put it back on the...
There could be several other factors influencing the behaviour of your optical mouse. Have you tried cleaning the lens underneath and also used a contrasting mouse mat on your table?
The range of this mouse is very limited (3ft) and you might have some interference from other devices around (like cordless phone, wireless devices and so on)
Check the following 2 sites for more troubleshooting ideas. Also the microsoft site referenced below provides some software you can download to diagnose better.
http://www.ehow.com/how_5142950_troubleshoot-microsoft-wireless-mouse.html
http://support.microsoft.com/kb/321122/en-us
Dec 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have microsoft bluetooth optical mouse 4000 it suddenly stopped connecting to the receiver, as I cannot move mouse anymore
Just to clarify, this is a wireless optical mouse, right? Please try the steps below:
1. Use fresh batteries.
2. Make sure that the mouse is turned on.
3. Check if there's a connect button on the wireless receiver and underneath the mouse. If there is, try holding down the two connect buttons at the same time for five seconds and then release them both.
4. Try moving the mouse.
5. Make sure that there are no possible wireless interference between the wireless receiver and mouse like the base of a cordless phone, cell phone etc.
If same problem occur after doing the steps below, then you may want to contact the manufacturer for RMA. This Microsoft 4000 has a three year limited warranty.
Thank you!
Nov 11, 2009 | Microsoft Wireless Optical Notebook Mouse...
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
Problems of connecting mouse
Insert the charged batteries in the mouse and press the Connect button on the USB plug. The LED on the plug will start blinking. Now check your mouse, it also has a connect button, press it and you can use your mouse now. In my Microsoft wirelss mouse the connect button in underneath it, near the place where the LED blinks.
Jul 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 30, 2009 | Microsoft Wireless Optical Notebook Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
I need connect my wireless mouse to my laptop
you must have got a usb device to connect your mouse to a computor with the muse itself. plug it in first and the mouse should automaticaly start working, if it does not, you wil have to install driver for the wireless usb device.
Dec 22, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Apr 28, 2008 | Microsoft Wireless Optical Notebook Mouse...
Microsoft Wireless Notebook Optical Mouse VSBX300001 Logo
8,699 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
