Question about Bush 5693D 24" TV
Bush 26 lcd tv
Standby light flashing
  • Anonymous Apr 29, 2008
    when i turned my tv on the standby light came on as usual but once i pressed the standby button the LED just kept flashing but nothing else happened, got the crackling when powered up to say it working but nothing else
  • walsh377 Nov 13, 2008
    when i turned the power on the tv crackles as it wants to power up but led just flashes red
  • Bush Master
  • 19,396 Answers
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
2 Suggested Answers
SOURCE:
SOURCE: bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Posted on Sep 21, 2008
I have a 26mf231 Magnavox 26 inch tv. The screen on the tv just flashes over and over. Never powers up. I took out the power board and all the capacitors look good. Thanks in advance
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 30, 2013 | Philips 26MF231D 26 in. LCD Television
The blue standby light on my bush 19" lcd tv stays on all the time but i get no picture or sound can you help.
The II2 Bus has the fault. It detects some malfunction from other circuit boards. Your TV need a through checkup. Contact any experienced service technician, as the work is a very skilled one, and not a user reparable.
Jan 05, 2013 | Televison & Video
Hi! I have a 32" LCD led backlit bush tv (not sure
Yes, all the issues point to a problem in the standby power supply which runs 7/24 if the set is plugged into wall power--get it taken care of under warranty before it really fails bad.
Dec 17, 2012 | Televison & Video
I turn tv on then the standby light goes green then goes to red flashing
It is a common Fault on some lcd tvs you will need a replacement switch mechanism fitted don't know the correct name for it but it can be fixed .I had exactly the same problem with my BUSH 26 inch LCD tv took it to a local independent tv shop and the owner repaired it for me it cost around £67 if my memory is correct this fault started on my TV 14 month after i bought it - 2 month out of warranty. hope this response helps
Good Luck
Eddie Hall
Nov 27, 2010 | Televison & Video
Polaroid 26inch lcd tvred standby light on but power wont turn on. I've unplugged the tv, changed the batteries in the remote. The tv stays with the red standby light only.
You need to open it up and checking the voltages in the power supply sections, you should have 5v (for logic circuits), 12v for sound, 24v for backlight inverter circuits. Look for bad caps with bulging tops in power supply also.
Jan 12, 2010 | Polaroid FXM-2611C 26 in. LCD Television
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
Bush 37 inch model no idlcd37tv27hd
the tv is going in shutdown mode, is going to be power supply problem. check if your tv is under warranty because you will need a tv tech,
Dec 12, 2008 | Acer AL2671W 26 in. LCD Television
BUSH IDLCD27TV006
http://www.chsinteractive.co.uk/pdf_data/KT02.pdf
Order Code….. KT02
POWER SUPPLY REPAIR KIT
BUSH MAXIM 1157 1154 Medion
Goodmans (Standard) 04TA069I 05TA71B 05TA071C
A standard power supply repair kit for faults attributed to the standby +5v rail.
BUSH IDLCD27TV006.
MAXIM 1154, 1157.
MEDION MD30112.
GOODMANS IDLCD27TV006.
The numbers off the boards will read: 04TA069I 26” 27” 30” 32”
& 05TA71B, 05TA071C.
LCD TV POWER SUPPLY PROFILO-TELRA.
Please check the primary of TR20 before fitting the kit.
Primary windings should read approx 2.700mH / 4.00 Ohm.
We recommend all kits are fitted by qualified engineers
We accept no responsibility for loss, injury or damage caused by your use of this kit as a successful repair
depends on your own skill and fault finding ability.
Circuit Reference
Loc Description
F300 T3.15A FUSE
IC21 FSD200
IC30 ICE1QS01
D315 12V ZENER
D318 2V4 ZENER
Q300 BC337
Q302 BC848C SMD
D325 1N4007
C213 33UF
C322 47UF
C356 47UF
C330 1000UF
LINK (IF NEEDED)
Oct 31, 2008 | Televison & Video
Bush lcd 27006 standby flashing
Jan 06, 2008 | Bush 5693D 24" TV
Bush 5693D 24" TV Logo
781 people viewed this question
Top Bush Televison & Video Experts
Vitally Alcher
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
