Question about Philips 50P8341 50" Rear Projection Television
Too much red
Everything has a red tint blue and green are muted. could this be an ic prob or coolant prob. If so step by step instructions would be helpful along with pics if poss. have new crt boards on the way
  • David Beck
    David Beck Apr 05, 2008
    so I should hold off on replaceing coolant and ic
  • David Beck
    David Beck Apr 16, 2008
    Ok replaced both red blue crt boards... Still too much red. have green now but blues are mutted or green and a blue halo around some whites.
  • Philips Master
  • 19,396 Answers
You should get rid of the problem when you replace crt board, that is usually the cause.
Regards
Posted on Apr 05, 2008
  • Ginko
    Ginko Apr 05, 2008
    Well, if you have already the crt board coming, in any case the easiest thing to do is changing the crt board.
    From your description I do not think it is a coolant problem , when you have to replace the coolant for one color, you get kind of blurred images too, not only one color that is missing.
    It could also be a convergence problem, but here as well, when convergence ics are gone you usually get a additional phoenomena than just one color missing. If you bought already the crt board, I suggest replacing it first. Eventually you can test the ICs pico fuses for continuity. Tey are often located under of the heatsinks which support the ICs.
    Regards
My tv has a red tint to it not sure what to do?
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 17, 2013 | Philips Televison & Video
Why does the tv look have a red tint all the time
The CRT coolant is needing replacement in the blue and green CRTs which make the red dominate. You can see the coolant is bad by looking in all three lenses you will see that the red is clear and bright where as the blue and green will be hard to see through which makes the colors dim. Replace the coolant should solve the issue. You can get the Phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for all three CRTs and the CD with instructions.
Mar 08, 2011 | Philips 50P8341 50" Rear Projection...
Has bad color,no greens and red tint.
Change the coolant in the CRTs. The blue and green get contaminated and cause the red to become dominate. You can verify this by looking into the lenses of the CRts with a flashlight and you will notice what looks like bacteria in the lenses indicating that the Coolant needs replacement. You can then get the CRT coolant kit at www.tvrepairworld.com which has the coolant and the CD with instructions for Phillips Tvs.
Dec 10, 2009 | Philips 50P8341 50" Rear Projection...
I have a philips dptv310 55'' rear projection tv... everything works but picture is in constant red tint... any fixes
The Phillips are famous for the coolant needing replacement in the blue and green CRTs which make the screen take on a red tint and the pic will appear dull. You can get the Phillips coolant Kit at www.tvrepairworld.com The kit also contains the CD with instructions
Nov 26, 2009 | Televison & Video
Phillips 52 in big screen screen has a red tinge other colors come though but not very bright
Replace the coolant in the CRts a very common problem with phillips. The colors will get very dim and red will become domintae as red seldom needs replacement where as blue and green get congealed and the set will get dim hard to focus and you will see a glowing around green and blue objects. Heres a link to the coolant kit for a phillips which contains the replacement coolant and step by step instructions on CD with pictures on how to replace the coolant.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
May 06, 2009 | Televison & Video
Changing oil, in guns RED Green Blue ( algae)
you can get the coolant kit which has the coolant for all three tubes and step by step instructions on how to do the proceedure on the phillips / Magnavox rear projection Tvs.Heres the link shipping is free within the US.
Apr 22, 2009 | Televison & Video
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Television has an extreme red tint
fluid comnated in blue crt and maybe in green
Jun 24, 2008 | Philips 43P8341 43" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
