Question about Kenmore 65924 Electric Dryer
Kenmore 90 seies belt replacement
The belt broke while i was drying shoes. i opened up the dryer and found the bely, but when i turn on the dryer i don't hear anything that sounds like a motor running, so i might have more than 1 problem. anyway my dryer's lint trap is inside the front door. dryer approx 8-10 yrs old or so. let me know if you can tell me how to change the belt, it will be greatly appreciated.
  • oacnmt Jun 28, 2008
    The tumbler stopped spinning
  • fdmust96 Sep 28, 2008
    belt broke around drum how do i replace it
    Genius:
  • 1,122 Answers
You have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Posted on Mar 01, 2009
Kenmore dryer does not have power
open your dryer door and turn the drum in any direction, if it turns real easy then it means that most likely your belt broke, and you have a safety switch on you dryer that cuts the power to the motor,
you can replace the belt
but most important , find out what made the belt go out, could be bad roller wheels, or bad pulley or just all of them..
Nov 14, 2012 | Kenmore Sears Dryer Replacement Kenmore...
Dryer heats up wont turn belt is fine
if you can't turn shaft by hand, motor sized or bearings(on both ends of shaft) shot.
Jul 08, 2012 | Kenmore Series 70 80 90 PN281798 Dryer...
Hunter, I have A kenmore electric dryer model 110.64121100. My problem is the dryer heats but the drum does not turn. This is a very strange problem. I turned off the timer and heater was still on in the...
Ok check the belt. if broken then make sure the drum turns freel by hand before replacing the bely. Usually dryers wont heat if the motor doesnt go so perhaps the motor is running without a belt. have a look see. Without an inspection its dificult to pin point Good luck
Jan 22, 2011 | Dryers
Dryer drum stopped rotating, dryer blower continues to work.
The belt probably broke, and coincidentally happened while drying the shoes. The belt is easy to replace. Open the back and you'll probably see the belt laying on the bottom
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
Kenmore 80 series dryer drum won't turn
ok you need to change the belt take model number off machine go to appliance shop get replacement belt open front of dryer belt goes around drum around pulley on motor then under tentioner pulley thank you for useing fixya please rate me
Feb 20, 2009 | Kenmore 73952 Gas Dryer
I have a Kenmore dryer, my son put his BIG basketball shoes in to dry and now the dryer runs, has heat and does not spin? Can this be fixed or do I need a new dryer?
I WOULD START BY CHECKING THE BELT. THE IMPACT OF THOSE SHOES MAY HAVE BEEN ENOUGH OF A JOLT TO CAUSE THE BELT TO COME OFF THE PULLEY OR BREAK.
Jan 26, 2009 | Kenmore 45081 Front Load Washer / Dryer
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Dryer does not turn anymore, dried shoes inside
the belt that turns the drum has broken or come off
you will need to remove the housing and replace the belt or call for service
Good luck
Jan 07, 2009 | Kenmore 62602 Electric Dryer
Dryer won't turn on
hi thanks for the question i would check the belt that is the cheapest to replace
Sep 25, 2008 | Kenmore 62602 Electric Dryer
Kenmore 65924 Electric Dryer Logo
175 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
