Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Bar doesn't turn unless vacuum is pushed.
Belt looks fine and turns manually. Suction appears to be less than before. Sucked up a piece of carpet thread which wound around bar. removed thread and now this problem.
  • kinpier Apr 05, 2008
    Forgot to mention it is a Dyson DC 17
Oh for crying out loud! That button has been there since day one but I NEVER looked at it! I guess I thought is there to be symetrical! I also sucked up carpet thread. I was okay for a while but when I then sucked up my dustcloth the brush quit. Usually this stuff happens right before the guests are due so at least this time I got to fix it without pressure!
Posted on Jul 17, 2008
This happened to me once before I was aware that there is a button to turn off the brush motion. It is the grey button beside the power button that has a picture of a brush.
Posted on Apr 11, 2008
Upright Vax vacuum has no suction or hadly none from the base. Belt, motor, hose all working fine
yes turn it upside down and look real close at the area where dirt goes .they do plug up when too much big stuff gets in there .
Jun 15, 2015 | Vax Vacuums
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
Mar 01, 2015 | Riccar Vacuums
Chess piece lost in shark navigator rotator
You must extract the chess piece or else it could move within the unit and cause further damage. If you cannot open the shark and get to the intake section, then have a service do it for you.
Feb 26, 2014 | Shark Helmet NV22L Shark Navigator Upright...
Brand new dyson dc46 beater bar not working
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 09, 2013 | Vacuums
The beater bar of the power head of my canister vacuum Electrolux 2100 turned off.while vacuuming,however the suction was in tact and the hose appears clear.
If you take the carpet head apart and take a look at the belt that drives the beater bar -- if it is stretched or broken, replacing it should resolve the issue. If the belt is in good shape, check the beater bar for debris that could keep it from spinning (I have long hair and it tents to jam up the carpet head of my vacuum on a regular basis).
If neither of the above solutions help, you might have an issue with a dead motor, or no power to the carpet head. Check that all of your connections are nice and tight and give it another shot. If it is still not working, I recommend bringing it to a repair shop to see if it would be cheaper to fix the part or buy a new one.
Jun 01, 2011 | Vacuums
I was running my vac when it caught the fringe on a throw. I turned it off and carefully pulled it out but now I don't have any suction and it's not cleaning the carpet.
Don't know the model too well but the beater bar is what goes when that happens(the brush that goes around right there on the intake of the sweeper) it has a belt that makes it turn and you probably broke the belt or burnt it up or it came off so it is the belt that is the problem. That will give you those symptoms because the beater bar (rotating brush) is what lifts the dirt up so it can be sucked in.
Mar 28, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Hi my dyson dc07 animal has suction but the brush bar wont turn. If I turn it on there is a horrible noise. The belt is still fine
The belt is probably worn or stretched. When this happens the belt won't turn the roller brush when it is against the carpet. Here is a link for the manual and links for the belt you need:
DC07 Manual
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Nov 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
123 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
