Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer cannot feed paper?
Paper cannot feed.does not pick up paper from tray.officejet 6110.
    Problem Solver:
  • 7 Answers
Open the cavity and make sure there nothing obstructing it.
Disconnect all cables and reconnect. Make sure it is properly hooked up to your phone and computer. Let me know if this helps.
Posted on Apr 07, 2008
SOURCE:
Stating that there is no paper but there is paper in the tray
Usually this means that the paper can't be picked up. First take out the paper and check for curled edges or wrinkled paper. Discard damaged pages. Check for torn corners and remove any small foreign objects. Make sure that the paper is aligned properly when you return the paper to the tray. If you only have a few sheets in the paper tray, add more paper.
Next check if the rollers are dirty. They can be cleaned with a damp lint-free cloth. (Just a little water is needed.) Check that the feed mechanism is undamaged. My home inkjet printer (an HP OfficeJet 7000) had a part of the paper lift mechanism break a few days ago. If you pushed the top sheet of paper just right, the printer would still pick it up. We noticed a loose piece when we opened the back of the printer for the straight-through paper feed. After attempting to replace that piece, we looked closer and another part fell out of the printer.
Some find it worthwhile to take apart the printer and re-attach the parts. If the printer is still under warranty, let HP do the job.
I hope this helps.
Sep 12, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
The printer keeps saying there is a paper jam at tray 1 but there is no jam
It is not picking up the paper. You need to either clean or replace the feed roller on tray 1
Jan 16, 2011 | Xerox Phaser 6110 Laser Printer
Paper will not pick up and feed thru printer
You pick-roller is to dirty and need cleaning.take a clean cotton or cloth peace and with spirt clean the roller.If you look in the paper tray you will see the pick-up roller.Replay if you need futher help!
Nov 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I am printing postcards which get stuck in the printer during the last 2 inches of printing. What can I do to fix this? The printer is HP officejet 6110 all-in-one.
How stiff is the card stock? Some cards cannot feed if the printer rolls the card to print on it. (This one does)
I have taped cards to a full size sheet of paper and run that through.
Usually this means the paper is too stiff.
You can try cleaning the paper feedroller with a rag with a bit of windex on it. (This roller is above the paper tray where the paper loads in.)
Apr 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Constant "paper jam" on HP 6110; then wrong size paper;
there are some broken parts on your printer it could be at the lower back portion of the carriage which holds or take control of the mechanical parts not to feed paper when initializing or it could be its counter part that is broken that could be found on the right side of the printer almost on top of the small gear of the output paper roller.
Aug 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Tray 2 Printing
Couple of things for you to check out.
1. Is that you've enabled the second tray for the printer. This is normally automatic but to check go to:
START > Printers > L7780 > Properties
- Click the "Device Settings" tab
... then sort out the different setting so they are all correct such as paper size and of course "Tray 2: Installed"
2. The other more common issue is simply that the printer isn't sitting properly on top of Tray 2 and as a result it's not engaging the cog wheel properly to pick up paper.
This is one of those trial and error things where you pick up the printer and re-slot it down onto Tray 2 until it works properly.
Hope that helps...
May 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Apr 28, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Paper in tray but message says paper tray empty
HP officejets are notorious for problems with paper feeding...
Try the solutions (ignoring the ones about tray #2) from this solution... They're all the same sort of printer feed mechanism.
http://www.fixya.com/support/t878735-printing_error
... also something I noted with the K850 (the earlier model to the K8600).. some papers are less likely to be picked up than others.
I had to get some cheap A3 paper for that unit which worked better than Xerox branded, higher quality photocopier stuff. Sounds strange but if it works...
Hope that lot helps.
Feb 22, 2009 | HP OfficeJet Pro K8600 Printer
Hp officejet 6110 malfunctioning
The paper sensor flag is probably stuck or broken. The part number is C7309-40013.
Dec 04, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
95 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
