Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite fridge crisper drawer freezing stuff
The veggies (and anything) in the crisper drawer keep freezing I have lowered the temp in both the freezer and fridge ?
  • 15 more comments
  • lign Apr 24, 2008
    needa crisper for my frig draw cracked i need a new one
  • Anonymous Jun 02, 2008
    My crisper drawers are freezing my fruits and veges. I have the top frig with the bottom drawer freezer. I am wondering what the correct temp in order to ensure that this doesn't happen is, or there is a fruit/vege dial for the drawers, should the dial be in the middle instead of to the immediate right or immediate left?
  • nosoda01 Jul 27, 2008
    The vegetable drawers and top shelf are freezing.  It is a Kenmore freezer on bottom/french doors.
  • Anonymous Oct 15, 2008
    items in crisper drawer freezing
  • gretchi2005 Jan 24, 2009
    My fruit and vegetables are all freezing on the correct setting!!!
  • Anonymous Feb 02, 2009
    I have the same problem with my bottom freezer frige.I have turned the setting down did not help.I am very frusterated. The vegys still freeze.
  • Anonymous Feb 28, 2009
    vegtables freeze on the lowest pull out shef. find myself throwing out alot of wasted food.
  • Sue 31 Apr 02, 2009
    Kenmore (not Elite) 18 cf freezer on the bottom fridge is freezing food in the crisper drawers.
  • Anonymous Apr 04, 2009
    the crisper is freezing in the back with alladjustments as highest temp. setting and the ice maker stoped working.
  • Anonymous Mar 12, 2014
    Have tried raising the cabinet temp, but my veggies are freezing in the bottom drawer of the fridge, the drawer above,holds my salad stuff, which I s ok. Tried closing the slide vent on the front of the drawer,as well as leaving open, costing me money, as. The veggies are going off !
    My LG side by side, is freezing the veg in the bottom drawer
  • Anonymous Mar 22, 2014
    fridge keeps freezing food
  • Anonymous Mar 24, 2014
    Kenmore cold sport
    Crisper drawer
    Kenmore cold spots
    Crisper drawer
  • Anonymous Mar 25, 2014
    water not condensating out of fridge
    water also below drawer freezes
  • Anonymous Mar 28, 2014
    Food contained in the Chiller/Crisper compartments are freezing. I have checed the sliders in the fridge & freezer compartments and they are both in the correct position for Crisper and not Chiller.
  • 42 Answers
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
Hi: I have a 9yr old profile refrig, mod #tfx25prb...
What is your refrigerator cold setting? Try lowering the temp to to the medium setting.
Items in the lower part of the fridge will freeze if the setting is too high. (P.S. Cold air "sinks" so the lower part of the fridge will be colder. Cutting the "number" setting on the fridge does stop air flow though.
Oct 03, 2017 | Refrigerators
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Vegetables keep freezing in the fridge crispers
You have to heat the coil in the back of the fridge. Take everything out and open up the back, then take a hair dryer and heat the coil. After doing this, adjust the heat settings on the freezer.
Nov 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Jul 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Nov 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Crisper drawer freezes veggies
need more info what brand model and is it a side by side or top mount ? more info will be helpful
Sep 13, 2008 | Kenmore 50522 / 50524 Side by Side...
Frozen Veggies in Crisper Drawers and Water under Drawers
water under the crisper doors is pretty common, all you have to do is raise the front legs of the refrigerator, Refrigerators have a heater in them that keep everything from freezing, if it wasnt for the heater then it would just be a freezer, now alot of these samsungs have 2 evaps, so if you get a warm fridge, its prob. because a sensor is out or the heater is out and there is ice buildup inside the unit preventing either the fan from turning, or just blocking air flow, but for the water, just raise the front legs and there is a drain in the back that it will go into from now on
Jul 29, 2008 | Refrigerators
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
2,952 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
