Question about Panasonic KX-TG5576 5.8 GHz Cordless Phone
Panasonic KX-TG5576 5.8 GHz Phones shutting down
Hi we have the above phone, great reliable etc. About 2 years old plus. Over the last 6 months the phones, even with a full charge are shutting down, sometimes and I mean sometimes it says get closer to base, but mostly just shuts down, mostly when we push talk. This happens if the phone has been off the base or charger for a little while. I recently bought a new battery thinking that would be the fix, but it is still happening to the phone with the new battery. The phones do not have any damage and have been fairly well taken care of. Can you help me? I cannot afford to replace the system at this time and if I did I would have to buy a cheaper model without talking caller ID...lol Thank you,
Dave Makaravage
[email protected]
SOURCE:
CORDLESSGURU
  • 106 Answers
SOURCE: KX-TG6071M 5.8 GHz talking caller id not working
Hi trinigirl, You should not have to do anything to make the caller id information come through. There is no programming to perform for the regular caller id identification on your display after the second ring (it takes at least one ring cycle for the digital information to pass through). Your model also has the talking caller id function, which will announce in English the callers name or a custom name you can prepare in the phone book of handset number 1. With all that said, you are not getting caller id showing after the second ring, then your phone is bad (which is pretty rare for this symptom), or your phone line still does not have caller id activated. To troubleshoot your problem you need another phone line with working caller id and/or a different phone that is known good to pass caller id. That way you can interchange the phones/lines to see if it is your line or your phone. My guess it is your line somehow, though I have fixed phones that won't pass caller id, but rarely. If it is your phone, try rebooting it, thats about all you can do short of sending it in for repair. Let me know how it goes. CG
Posted on Feb 19, 2008
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
SOURCE: caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
Posted on Sep 25, 2009
SOURCE: I need CD software to main Panasonic KX-TG5576
I find main own CD software.Anyway Thank You for your answer.
Posted on Oct 04, 2009
SOURCE: Purchased Panasonic KX-TG6431 with total 4
Since you are asking me how did i solve it without you giving me any solution or hint,how do you expect me to tell you .You want money for advising me then i also need the same if you want solution.
Posted on Oct 07, 2009
Batteries failing
one would certainly think the batteries are replaceable .
Mar 19, 2015 | Panasonic Lands Phones
Changing the time settings
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.:
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Mar 28, 2010 | Panasonic KX-T7630 Corded Phone
I need to change the time on my panasonic kx-t7630
Mar 27, 2010 | Panasonic KX-T7630 Corded Phone
How do you change the clock?
Mar 18, 2010 | Panasonic KX-T7633 Corded Phone
HOW DO YOU SET THE TIME
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
HOW TO SET THE TIME KX-T7636
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
Mar 14, 2010 | Panasonic KX-T7630 Corded Phone
HOW DO I CORRECT THE TIME ON THE DISPLAY
Mar 02, 2010 | Panasonic KX-T7630 Corded Phone
How do I reset the time? Cannot find in the manual.
Feb 03, 2010 | Panasonic KX-T7630 Corded Phone
How i setting the hour in the KX t7630?
Jan 25, 2010 | Panasonic KX-T7630 Corded Phone
Kxtg2000
As the voicemail system can be quite complex with mailbox password setting etc. I think you will need the manual to help you along at some stage, so here is the link, just click on "download"...cheers.
( it's free )
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/2-4-GHz-Phones/model.KX-TG2000B
Jan 22, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG5576 5.8 GHz Cordless Phone Logo
97 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
