Samsung washer/dryer code problem
Modle number SAMSUNG WD-J1255CI/XSA .every time we try to dry clothes it runs for about 5mins then shuts down and flashes a code FE we have looked in the manual and have found nuthing PLEASE HELP
  • dawnandian Apr 22, 2008
    Hi, we have exactly the same problem with the Samsung WD-J1255CI/XSA. We just got it delivered today. It dries for about 5 minutes and then shuts down displaying the code FE. Anybody know the reason?
Hey, I have the same problem and I am trying to fix it, anybody have any tips?
Posted on Jul 29, 2008
SOURCE:
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
Dryer runs for five minutes then stops, so has power. there is no error code, where do I start to find problem?
Usually with no error code its almost always in the board ..My suggestion is try to run it through test mode if it wont run through then replace your main board.The papers for this should be under the top panel tremove it look for some papers usually on the left as you are facing your dryer hope this helps
Mar 02, 2015 | Samsung DV218AEW Electric Dryer
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
SAMSUNG --MODEL# DV3C6BEW/XAA NOW COMPLETELY SHUT OFF. CAN NOT TURN ON OFR OFF EARLIER -NOT HEATING PROPERLY, TAKES A WHOLE DAY TO DRY CLOTH.. IF YOU SET DRYER TO 60 MINUTES, IN 15 MINUTES, IT...
dryer has a restriction in the venting process; disconnect vent hose and run dryer should work, if not then you will need to take apart and clean out all the lint inside the dryer.
washer:
http://www.ehow.com/how_4910369_troubleshoot-washing-machine.html
Jan 11, 2011 | Samsung Dryers
Prolem drying clothes
I just contacted Samsung Tech Support for my wash/dryer combo WD-J1255C.
The reply.."it is not a full dryer ...and it is not sold as a full drier.. and don't expect it to be completely dry". I queried why it is advertised as a dryer and got the same reply.
Its a great washer but why did I pay extra for the dryer combo?
May 18, 2009 | Samsung Washing Machines
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
371 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
