Question about Toshiba TZ50V51 50" Rear Projection Television
Tz50v61 I have a new screen but can't get the front of the t.v. off to slip in the two screens. How to disengage screen holders?
  • Toshiba Master
  • 8,617 Answers
On most projection sets you have to remove the speaker grille and you will find that the screen assembly frame is secured by a few screws along the bottom edge then the assembly slides up releasing the clips that hold the assembly to the case.
Posted on Apr 05, 2008
Broken screen
Lenticular ( front ) # 23430608
Fresnel ( rear ) # 23430607
I have tried 5 different wholesalers and all said No Longer Available
If you do find them, yes you can replace them yourself.
Jun 25, 2009 | Toshiba TP55G60 55" Rear Projection...
Would like to remove screen.
Easier to remove the top back cover, be carefull it`s heavier than it looks, has a large mirrror on the inside of the cover, hope this helps, video-tek
Feb 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Cracked screen on my Toshiba TZ50V61
maybe I can get you one but I need the sizes in inches by the way some tv has more than 1 screen can you tell me if all of them are broken? I was unable to singn in for a while due to a problem in the system
Oct 13, 2008 | Toshiba TZ50V61 50" Rear Projection...
I need to the outer protective screen for TZ50V61 too
did you make sure that the others screens are ok?I think there are three
Jul 28, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba tz50v61 replacement protective screen
Andrews Electronics
www.andrewselectronics.com
25158 Avenue Stanford
Santa Clarita, CA 91355
  • Phone: (800) 274-4666
  • Fax: (800) 289-03
Apr 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba rear projection screen
Hi Shaun. I just picked a new lenticular screen for Toshiba TZ50V61. I went to their Web-page and it showed me where there was Toshiba -based warranty shops according to Zip or area code. I went to one near my area and ordered a screen. It took three weeks to get to me and cost $170.00. I live in Canada so you might get one faster and cheaper.
Mar 24, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Need a new screen
Check out PACPARTS.COM..They have a lenticular screen in stock for 117.00..Type in the model number of the set and you can see a list of all replacement parts. Hope this helps
Oct 10, 2007 | Toshiba TZ50V61 50" Rear Projection...
Black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Sep 28, 2007 | Toshiba TZ50V61 50" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
