Your alternator can be rebuilt with parts from honda. At this point a new one would have been the way to go. It is possible you are having a problem with the wiring harness( broken wire, bad fuse block,etc.) You may even have a problem with the contact base of your ignition switch (dirty or broken). It snaps on to the bottom of the key switch. Mine stranded me at Mount Rushmore. I was able to take it the ignition switch, put in the on position, remove the contact base, disassemble it,scrape the contacts clean , put it back together, and drive away. Hope this idea helps with the problem.
