Question about RCA D52W19 52" Rear Projection Television
It blowing main fuse
The tv was dead and the main fuse was blow i change the main fuse and plug back in and it blew on pluging it in any idea i need help thanks
  • RCA Master
  • 8,617 Answers
That set will need some trouble shooting you have a short in the power supply. Could be alot of different things.
Posted on Apr 05, 2008
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
My kenwood reciever kr-a4070 keeps blowing a fuse
have you tried a different outlet? something my be wrong internally
Jul 31, 2012 | Kenwood Audio Players & Recorders
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
I was in the process of changing from a 220 3 prong to a 4 prong. I initially got the wire colors crossed. This blew the main fuse, which I reset. I found the proper wire order, and the fuse does not blow...
You have 2 fuses. You may need to change them both. Also make sure you do not have circuit breakers. There will be two breakers also. Trip them all the way back and then forward.
May 19, 2011 | Maytag Dryers
Watching the TV and heard a "pop", it went dead. Opened up the back and found a blown 4A 125V fuse. Replaced fuse and plugged in TV. Fuse blew instantly when I plugged in the TV. Sylvania...
The power suply unit may be dead......if the fuse blows instantly it means that the main input is short.
possible parts damaged :the diodes from the mains, the power tranzistor and the ic from the primary part and other components around them.
First unplug the tv, unload the mains capacitor (using a light bulb) check all the diodes from the rectifing bridge, check for any shortened semiconductors or blow resistors.
BE VERRY CAREFUL !!! THERE IS A RISK OF ELECTRIC SHOCK ,IF U DON"T KONW ANY ELECTRONICS TAKE IT TO A SPECIALIST
Feb 19, 2011 | Sylvania LC370SL8 37 in. LCD Television
I have a wd 62725 we had a power failure last night and now i have no lamps no fans nothing tv is dead i have reset several times tv was pluged into a surge protector and all of the other items are still...
Yes, apparently fuse is blow off. You need to take off back cover of TV and follow AC cord to reach on power supply board.
Get service manual from Manual Zone for small fee, if you need detailed technical info and schematics of TV.
Apr 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Tv is pluged in,will not come on when on button is pushed
is the unit competly dead? no flashing lights.first unplug the set for 30 min then plug back up and try again if there is no lights then i suspect main fuse has blown. however this does not mean replaceing will fix. something has shorted to cause fuse to blow if there is flashing then the computer in the set has seen something wrong and shut down.
Mar 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not light up.
Your main fuse blew if its dead but it could have caused other issues with an electrical spike when the power went off, this is kind of common..pull the back, replace the main fuse and see if it blows it again, if it does then the diodes in the hot side of the power board are bad and would need replacing.
Dec 09, 2017 | Televison & Video
Flat panel tv blows fuses
next to the fuse that blows is 4 large black diodes2.gif.one of those is common to short out. the bad one would give you areading of zero ohms when checked with a meter. or just replace all 4.most likely its location D603. hope this helps
Nov 10, 2008 | Sylvania 6626LCT 26 in. LCD Television
27F522T RCA
REPLACE IT! IF IT BLOWS AGAIN THEM IT TIME TO SEND IT TO A SHOP
Dec 06, 2007 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
