Question about GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool dishwasher washer wont drain
    Sergeant:
  • 198 Answers
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Posted on May 31, 2009
    Sergeant:
    Champion:
  • 219 Answers
Remove hose from under sink find a pale and push drain into pale if no water comes out there may be obstruction in drain hose good luck:)
Posted on May 07, 2009
SOURCE:
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Washer wont drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 13, 2009 | Whirlpool Washing Machines
Whirlpool dishwasher wont drain even on cancel/drain but motor hums
We had this same problem, and after we looked in to it, it was the connection between the drainage tube and the garbage disposal. The plug between the disposal was not punched out prior to the dishwasher being hooked up.
You will have to take off the disposal, get a hammer and screw driver and punch out the plastic piece that is blocking it. Dont worry if it doesnt come out at first, you have to use some force behind the hammer. After it is punched out, reach in and remove the plastic piece. Then hook the disposal back up and then the drain pipe to the dishwasher.
Put the washer on rinse to test it and make sure all the connections you messed with do are not leaking.
Hope this helps!
Jul 07, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Have a whirlpool dish washer it wont work the cancel drain button is blinking how do i reset that thanks
have you tried refilling salt and rinse aid?
if that do'nt work it probably needs servicing it could be drain pipe blockage.
Jun 17, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Jan 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher
Hai this alf project post of solution
May 09, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
GE Tritonr XL GSD6260JCC Dishwasher Logo
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
