Question about Canon PIXMA MP210 Photo All-In-One Printer
Pixma mp210 - e2 error
New printer, need to use asap for professional project - not working at all - truied all recommended but can't get past e 2 2 flashing error. close to smashing the plastic junk heap. any ideas very much appreciated.
    President:
  • 2,351 Answers
Go to this cannon link & type in the search windows error e2 than click search. If nothing helps or fix's the printer call Cannon.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15402
Call Canon here:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2110&fcategoryid=238&modelid=15402
Mike
Posted on Apr 05, 2008
Pixma mp210 e2
Use a piece of thin card or stiffer paper that is A4 size & try to print something.
When the paper starts to move, push it through to clear out any debris. If that doesn't fix it, get in touch with the store you bought it from, or Canon. They should be able to help - especially since it's brand new.
Jan 14, 2014 | Office Equipment & Supplies
Cannon MP 210 E2 Error
Is the printer new?If so,make sure you remove all the packaging materials.
  • Ensure you load the paper properly.
  • Press the on/off button.
  • Reset the ink cartridges.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
What is error code 2 on a canon MP210?
This steps may solve your problem.
1.Load paper correctly then press black or color button (MP210)
2. Press on/off switch to reset the multifunction device
3. Remove Packing Material MP210
4. Reset ink cartridge MP210
5. The MP210 may require repair
If your printer is new , make sure the packing material inside the printer has been removed. You should have a quick setup page and/or users manual that will show you how to remove any packing material that is inside the printer.
If this is an older printer that has worked in the past, start with step
1, 2 and 4. If this does not work contact the Canon customer s
Dec 13, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Display flashes e2 alarm light blinking won't print or copy
E2 mean reload the paper correctly and press Black or Color key from panel board.
Dec 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hi i have a canon MP210 and it is showing E2 and the alarm lamp is flashing. there is ink and paper in it any suggestions??? I can't find the user manual!!
E2 – No paper, Paper does not feed error.
How to correct, fix: If paper is not installed, load it and then press the <Black> or <Color> button. When paper is installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Nov 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 5100 on off blinks twice alarm blinks once E2 in window
Errror code E2 indicates a paper-out situation. Fill the paper. If it's full, fill the paper out and reinsert it. If that doesn't work, try this...
1. Power off the printer
2. Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3. Hold the Power button for 6 Beeps
4. Release the Power Button
This will reset the printer and should resolve incorrect detection problems
Nov 15, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My rinter keeps saying e2 what does mean
Error E2 means paper Jam and is it a Canon printer ??
Make sure you open printer slot and take out the jammed paper, it there is one.
Retry and hope it works !!
Thanks !
Sep 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Hello my canon mp210 shows an error E 2 please help thank u
Check to see if your ink carriage is sliding across when you turn on the printer.
If not turn off open scanner to turn and and slight pull to start to reboot cycle.
That is what I had to do with mine when it was flashing E2
Jan 09, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp 210
According to Canon you should:
1. Load paper correctly then press Black or Color button (MP210) 2. Press ON/OFF switch to reset the multifunction device 3. Remove Packing Material MP210 4. Reseat ink cartridge MP210 5. The MP210 may require repair
All steps can be done individually and if the error goes away the other steps don't have to be done. Hope this helps.
Oct 06, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 printer all-in-one
goddman it same issue here - brand new, not working, drives me nuts - anyone solved this yet?
Feb 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
9,066 people viewed this question
old marine
old marine
Corne Viljoen
