Oil leaking from the bottom of a top load washer.
  • 2 more comments
  • ed odom Apr 21, 2008
    YELLOW OIL IS LEAKING OUT OF BOTTOM OF WASHER.
  • compostanu Jun 20, 2008
    Similar Model - GE Select Model S2200Y0WW
    Brownish oil leaked out of bottom of washer. Cannot find leak or where it came out of gear box. Covered entire bottom panel and then ran out onto floor.
  • Anonymous Dec 27, 2008
    oil leaking out the bottom
  • reed_46052 Feb 13, 2009
    I have the same problem with my maytag - it appears that grease is leaking out of the bottom of the clutch - possibly comming from the transmission - apparently there is a grease seal between the transmission and clutch that has failed - how do you change this seal?
    Reed
SOURCE: whirlpool washer leak
most models have a screw on each side of the head assemly.. in front or rear.. new models have a clips under each side.. remove the screws or push up on clips.. flip the head back and you will see 2 clips holding the body on.. remove clips and whole body of washer will come off... will probaly be water pump linking.. have only had few with main tub seal leak
Posted on Sep 02, 2007
  • 1028 Answers
SOURCE: Maytag top load washer
usually tub seal ck pump and hose to pump but my bet would be tub seal
Posted on Apr 24, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore top load portable washer leaking, model 110.42722200
Replace the water pump. The seal is leaking.
Posted on Jul 16, 2009
  • 672 Answers
SOURCE: Water leaking from kenmore top load washer
If the plastic piece you are refering to is the pump, yes it is replaceable. The pump is on the front of the motor on the under side of the machine. It is located front and center and has a history of wearing the case from the inside out. The part is available at www.sears.com under the parts direct tab. You will need your model number to find your machine and then the replacement pump. The model number is three digits a decimal and the remanider of the number, aka. 110.5555555. The model mumber is usually under the lid, on a top loader. Instructions are not included with the pump, so if needed here they are./// This will remove the case.///
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or two hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward and remove the case. ///There are two clips holding pump to the motor. Remove the clips and pull the pump forward. There may be some residule water in the hoses, be prepared, disconnect the hoses and the pump is out. Reverse the procedure to install the new pump and you're in the laundry business again. Good luck. Need help? I'm here. Just post a response and I'll get an email from Fixya.
Posted on Aug 01, 2009
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Whirlpool Gold Ultimate Care II washer is leaking oil and water. Water is not leaking from the hose connection but seems to be coming from bottom of washer, as is the oil. Is it dead?
never dead just depends how much time and money you want to spend
new pump $60.00 dollars
new coupling $22.00
new tub seal $15.00
transmission and tub seal $236.00
specialty tool spanner wrench $16.00
this is just parts if you decide to replace installing yourself
Jan 27, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaking oil
If the oil is leaking at the top of the tub, around the agitator, you will need to dig out and repair the brake and drive tube. If it is leaking at the bottom of the washer, about a quart, you will need to replace the gearbox.
Sep 05, 2010 | Kenmore 24032\24036 Top Load Washer
Will not wash or spin but it will if i help it
check for oil in the bottom of washer. if oil is leaking it needs a transmission
Feb 05, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Thick Gear-like oil leaking from the bottom somewhere
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
Jul 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking oil from the bottom of the machine
Hi, Your problem is quite terminal, but easy to fix. You will need to replace the gearbox in the machine will cost around £150.00.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Jun 17, 2008 | GE WBSR3140DW Top Load Washer
Leaks lime looking oil
The problem is the bottom transmission seal. This can be fixed with a few basic tools without calling a tech. Lay the washer on it's back, block up the tranny support and remove the pulley and seal. you might want to consider changing the belt and lower transmission bearing also. Total price of these parts should be around $50. Don't worry about the loose of oil.
Dec 22, 2007 | Washing Machines
Washing Machines Logo
382 people viewed this question
Top Washing Machines Experts
