Question about Sylvania SST4322 32" TV
Video Channel Been using an 'Old" SST 4132 as a security monitor, with feed from a live camera feeding into the RCA video input on front of tv. Problem, is that TV "Lost" the video channel, and I cannot get that channel back (no remote with this TV). Sometimes there are 125 channels available, sometimes 69, but no video channel. Anyone got any suggestions as to how to find the video channel.
Does anybody ever solve these problems? i keep looking and not a single one has a solution.
Posted on Nov 23, 2008
SOURCE:
Does anyone know a way to hard wire my wireless security camera to my tv or comp?
Hey there!
You must have the Video card with the receptors for the TV, which is normally to the front or the back of the TV; of course the ability to turn the channel to input 1 or 2 as the case maybe. You must also have the power adapter for the camera, plus the BNC adapter from RCA to BNC. The computer needs a PCI video card, with similar fittings. Tha's it.
Sep 12, 2015 | SWANN Home Security
Hdtv optical audio output works except in tv mode
Unplug one of the RCA plugs one at a time, see if sound changes to no buzz but one ear channel only. The buzz can occur when RCA is not connected correctly and the video feed is put onto the earth wire of both audio feeds.
Dec 15, 2013 | LG Televison & Video
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
How would i connect my jvc everio to my laptop for a live feed
To enable a live feed from your camera to a separate TV/Monitor, you will require either the special AV cable (3.5 Video/audio plug to 3 RCA), or an S-Video cable (as per diagram below):
Cheers,
Scott
"Please be kind enough to rate this solution with a 'testimonial' or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 14, 2011 | JVC Everio GZ-MG21 Camcorder
Only VCR2 sound working, no video
if you want you can bypass the video instead of plugging it on your system feed it directly to your tv., you only need the white and red cables for your audio to work, red for right channel and white for left channel the yellow one is for video, you can directly plug it on your tv
May 05, 2010 | RCA RT2250 System
Stereo Set up
The physical TV is at best a lo-fi 2-channel analog audio device. Think about it this way: Most high-end users use video monitors (no audio or speakers on board). So where does the TV-related audio come from....
It comes from the same place the TV would get it - cable, satellite, dvd, blu-ray, vcr...
So why run audio from any of those sources to the TV and back to the receiver (whose specialty is
multi-channel sound)?
I imagine your cable or satellite box has Digital and Analog Audio Outputs. The receiver needs a digital input for anything multi-channel. Select the highest-quality one that's compatible with your HTR and use it for the audio feed.
You have one coaxial and one optical digital input. I imagine your (unnamed) DVD player has one or both types and your cable box has one or both types. If you have one of each type you're golden. Run each to its compatible input on the HTR.
If they're both optical, you have to make a choice, but if they're both coaxial only you could get away with using an RCA Y-cable to bring them both in to the one input. Then for each to work you would have to make sure the other device is turned off.
The video capabilities of this unit are limited to Composite (single RCA cable). Run one from the DVD and one from the cable box Video Out to the conveniently labeled inputs that match them.
I have no idea what your TV/Monitor has for inputs. If possible run the absolute highest quality video [HDMI, Component (3 RCA cables) or Composite (single RCA cable)] to the TV's inputs along with an RCA pair from DVD and Cable Ananlog Audio Out to the corresponding Audio In's on the TV. This way you can watch and hear TV from its own speakers without needing the Yamaha fired up.
Mar 15, 2009 | Yamaha HTR-5540 Receiver
S-video and phono video outputs not working
will it feed in to the tricaster at all?? if it does not then check your input typer and make sure its set to s-video and not composit, if it is working then make sure your connected to the correct output, the tricaster has alot of them and honestly i could only get the one's on the first card to ever work, also try feeding into it from the output on the front.
Mar 02, 2009 | NewTek Tek Tricaster Live Production...
I recently purchased an xbox, but because of the cable box, i dont know to to get video
Your cable box and TV should have RCA input jacks (Red, White, and Yellow) Red & White are for Audio and Yellow is for video feed...
HD Receivers & HD TV's are just slightly more upgraded with better video feed connections.
HD video can use three color coded RCA jacks for the video feed or a HDMI cable; if you can use the HDMI connection on your TV I recommend using that because it's less confusing to plugin the input cables. Try turning your TV to it's side to see what inputs you have available to connect your device to.
After you have it pugged your device into the input jacks press the "Input" key on your TV remote and power up the device.
Most TV's have more than one input, so you may have to cycle through the TV inputs by press the input key again until the video feed is displayed.
(If you don't have a "input" button on the TV or remote control you can try entering channel "00")
Nov 28, 2008 | RCA T09081 9 in. TV/VCR Combo
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Sylvania SST4322 32" TV Logo
172 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
