Question about Olympus FE-220 Digital Camera
Flash issues My camera is brand new, I just bought it yesterday and it will only take pictures without flash. When I put the flash on, it will not take any pictures and it has a little red arrow, like the flash arrow, but its red and its flashing. Does this mean that the camera is no good.
  • 4 more comments
  • fresita Apr 05, 2008
    I will try that thank you. :)
    How long does it usually take to charge the flash?
  • fresita Apr 10, 2008
    thanks, but i returned the camera, apparently, there was a malfunction. :) Appreciate your help.
  • DiRosie May 07, 2008
    I am having the same problem but i have had my camera for about a year and have successfully charged and used is many times. Now suddenly the flash indicator won't stop flashing and the battery is fully charged.
    Please help.
    Dianne
  • ana17 May 20, 2008
    My camera that i have it only take pictures without flash and when i put the flash on, it will not take any pictures and it has a little red arrow, like the flash arrow, but its red and its flashing.
    My camera that i bought it will only take pictures without flash and when i put the flash on, it will not take any pictures and it has a little red arrow, like the flash arrow, but its red and its flashing.
    Problem Solver:
  • 19 Answers
It means that the battery is charging the flash! Wait a while and it should stop. Then take your photo.
Do make sure your battery is fully charged.
Posted on Apr 05, 2008
  • Ian Ballard Apr 05, 2008
    If the battery id fully charged we are talking a matter of seconds...say 5 to 10.
    Did you charge the battery? If you placed it in the camera straight from the box it will not be fully charged; it will have only a test charge on it.
Flash won't retract
Page 27 of the user manual says:
Lower the flash by gently pushing it down. When not taking pictures, lower the flash.
The manual is online with Nikon USA. but here is the picture of that page. See bottom of the page.
Jan 11, 2014 | Nikon COOLPIX S9500 Digital Camera Black
Brand new camera, inserted the flash card, formatted per instructions. I take a picture but I can't play anything back. It does not record pictures on the flash card. If I remove the flash card and use...
Hello drlokeshyada,
Please be sure the card you are using is between 2GB to 8GB, class 4 speed or higher. If your card meets these specifications, then this may be a card compatibility issue. Please try a different card brand as sometimes a certain brand may not be compatible with a certain electronic device.
Aug 08, 2011 | Intova CP9 Digital Camera
Is it OK to use a Pentax AF500FTZ flash on-camera with a Nikon D70s? Is the trigger voltage going to be a problem? It looks like one can use a Nikon flash on a Pentax DSLR without problems.
The brands use the flash contacts to communicate to the camera. They do not make their flashes compatible with other brands. Don't mix brands. Even if trigger voltageis not an issue, the TTL and AF is not going to function.
Mar 24, 2011 | Pentax AF-500 FTZ TTL Flash
Brand new battery won't hold charge. Camera is three years old. I bought an extra battery when I bought the camera. They both seemed to go bad at the same time, so I recently bought two new lithium...
if this happens even to new batteries, it may no longer be an issue with the batteries, but it can be an issue with the camera itself. check the maximum number of shots that the camera can take with the batteries per its specification. if it should produce more, it would be a good ide ato check with Canon to have the camera checked.
Sep 06, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Canon powershot SD600 - flash doesn't work
It could be the sensor or a short in the flash wiring. You should take it into a camera shop and have them look at it. You could be covered under warranty if the camera is less than a year old.
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Flash troubles- timing off or something?
this problem is fixable. set the camera under the fill-in flash mode. do the ff:
-click the flash button, (right button that has broken arrow on it)
-click it for many times until you see the icon of a big crooked arrow without something with it on the screen, that means your camera is nder the fill in flash.
when set under this mode, the flash will work in any instance you're in. because under the red eye function, flash is usually turned off.
Dec 23, 2007 | Samsung Digimax S500 Digital Camera
Olympus FE-220 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
