Question about Microwave Ovens
My spacemakerXL Microwave is only 2 yrs. old. It started making a loud noise (like the fan) when turned on. Then durin the heating cycle, the (?fan?) stopped completely. The appliance still heats, but it only hums, not like it had normally sounded. I,m not talking about the exhaust fan; it stil runs properly. This happened about three weeks ago and I,m afraid to use it. Please help me! T. Edwards
  • Microwave Ovens Master
  • 9,174 Answers
Yes! I would not use it until it is fixed, because it sounds like your internal cooling fan is not running. This means your magnetron is not being cooled and will be destroyed if run too long with no cooling.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
How to change the fan
The fan is located on the right side behind the key panel. I know this because I removed it while replacing the magnetron the other day. It is easier to get to than the magnetron. You take the black cover off. Then there is a silver cover with 3 screws covering the magnetron. Remove it and remove the front grill and one screw to the keypad, then you can reach the fan thru there.
i hope this helps!
Oct 28, 2008 | GE JVM1631 Microwave Oven
Microwave makes loud noise and does not heat. Smell of light burning
yes anything can be fixed but a do it yourselfer i reccomend against this cause thats a radiated element in the micro
recommend go out and purchase a replacement go with G.E. they have the 7 year warranty great little micro. too change out is easy
Jun 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
Noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Nov 11, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
70 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
