Question about RIM BlackBerry Pearl 8100
Backup internal battery for Nec MobilePro 880
How do I replace the backup battery and where can I buy one? Thanks.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 230 Answers
The first step is to remove battery, then remove the rom cover screw and the cover, and the other 8 screws on the bottom. Flip it over and there are two screws on the other side that are normally hidden by the battery. Remove these two screws. Now carefully remove the two ribbon cables from their connectors. The connectors unlock by sliding the connector lock to loosen the ribbon cable. If you have never seen these type of connectors, then get help. You don't want to break the connector or the cable here or you will be screwed. Now open the NEC part way to about 45 degrees. Stand the thing on edge, and between the darker gray plastic and the silver plastic on the bottom half, that is the part that contains the keyboard, and the bottom case half, carefully spread the seam apart. The parts snap interlock with each other. Slowly separate by starting in one spot and working around the edge from where you decide to start, pry it apart a little further....eventually you will separate the two part entirely. Once you do that, you will be able to view the motherboard. If you need to, there are a few screws that secure the motherboard to the bottom half, and a cable that secures the lcd to the motherboard. On the 780 there will also be a cable for the thumbwheel. You at this point, you should be able to see the battery towards the back edge of the Nec pretty easily.
Posted on Apr 21, 2008
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Service Pack 1
NEC Computers has developed a service pack to address several service issues with MobilePro 780 and 880 handheld personal computers. To assure proper operation, NEC Computers strongly recommends that you update your MobilePro 780 and 880 systems immediately by installing this service pack according to the installation instructions. * Download Service Pack One for MobilePro 780 and 880: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp * View Installation Instructions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Installation * See Contents of Service Pack: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#Contents * Read Additional Frequently Asked Questions: http://support.necsam.com/mobilesolutions/FAQs/display/default.htm?itemID=2001186#FAQ Installation Instructions for Service Pack One for MobilePro 780 and 880 First download the service pack (MP78_UPDATE.CAB) to either your HOST or MobilePro system. It must be manually loaded onto your MobilePro by either using a dial up connection, PCMCIA Flash card, or from a connected PC before continuing with the installation. To install the MP78_UPDATE.CAB file, follow these steps: 1. Back up your MobilePro data and configuration using the Microsoft ActiveSync backup procedure. For details on using ActiveSync, see your MobilePro User's Guide. 2. Perform a Full (hard) reset on your MobilePro. Caution: Performing a Full reset erases all your data. Your MobilePro resets to the factory default settings. Please perform the backup first or you will lose data! 3. Copy the MP78_UPDATE.CAB file to you MobilePro desktop. 4. Install the service pack by double tapping the MP78_UPDATE ICON with your stylus. For proper installation, you MUST accept the default location - \Program Files, by clicking OK. 5. The following Message box will be displayed: Warning !!! 1. In order to ensure these patches are properly installed you must perform a Hard Reset prior to the installation. 2. You must back up all application and data files before performing a Hard Reset. The Hard Reset WILL ERASE all applications and data stored on this Mobile Device. 3. This file must be installed immediately after performing a Hard Reset on the Mobile Device (before any applications are reinstalled). 4. Press CANCEL to exit. Or Press CONTINUE to install this file. 6. Press Continue to install the service pack or Cancel to back up your data. 7. When the Setup Finish message box is displayed, Click Ok. This will remove all temporary files from your systems. 8. When the Setup Complete message box is displayed, click Ok. 9. Perform a Soft reset on your MobilePro. 10. Optionally, restore your MobilePro data using the ActiveSync restore procedure. 11. Once the service pack is installed, NECC recommends that you use the ActiveSync b
Service Pack
Error message "Backup Battery Very Low"
The MobilePro 900 back up battery is low and should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the "MobilePro 900 Handheld PC's User's Guide" for detailed replacement instructions.
Sep 14, 2005 | NEC MobilePro 900 Handheld
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
Coin cell backup battery
No the coin cell backup battery is not rechargeable. If the MobilePro 900 back up battery is low it should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the “MobilePro 900 Handheld PC’s User’s Guide” for detailed replacement instructions.
My system will not power up after I allowed the batteries to fully discharge. What should I do?
On MobilePro systems, which both batteries have fully discharged, the user must perform a hard reset after charging the batteries for approximately 10 hours to ensure proper operation. If the systems fails to power on the user must perform a "hard" reset to initialize the power management circuitry.
RIM BlackBerry  Pearl  8100 Logo
225 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
