Question about InFocus IN72 Multimedia Projector
IN72 On my IN72, after power up the startup screen appears ("infocus the big picture screen" - red) but then nothing else happens and I no button respond anymore. On the other hand it is connected with the HMDI cable to my computer and the computer identifies the projector correctly,
  • 563 Answers
Try using a different cable.
If the response is the same on a different cable , then the Mainboard might be at fault - this machine should still be under warranty and the warranty will cover repairs.
Posted on Apr 07, 2008
SOURCE:
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
I have an IN72 Infocus DLP Projector, after plugging in the power source to a dedicated outlet and verifying that outlet was good I can not turn the projector on. As soon as the plug is inserted into the...
power supply needs to be replaced. you can get the part from an infocus service center, or send it to the to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 10, 2010 | InFocus IN72 Multimedia Projector
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Infocus IN72 Projector. NO POWER OR NOT POWERING UP
This model projector is very sensitive to internal heat. I f by some reason the projector was abruptly powered down without the use of its normal procedure, in other words, unpluging cord from wall while on or power outage in premises, then the heat remains trapped and the sensors overheat and subsequently shuts down the unit. Now, although, once the sensors cool down it should reinstate operation some sensors become permanently damaged due to the extreme heat. In this case without having more facts, i believe it is the cause. I recommend a free check up to your nearest shop, most shops will offer free check ups.
Jun 07, 2008 | InFocus IN72 Multimedia Projector
Infucos IN72 projector
Hi Ronnel
This is a common Mainboard failure on a Projector.
The unfortunate thing is that the Mainboard will either have to be repaired or replaced.
Apr 18, 2008 | InFocus IN72 Multimedia Projector
Only power button responds, nothing else
Hi there
This unit should still be under warranty - take it to your nearest InFocus dealer.
If no signal is picked up then the Mainbaord is faulty.
Mar 28, 2008 | InFocus IN72 Multimedia Projector
No startup screen
Hi there
This not a firmware problem , but a Mainbaord issue.
If the unit is still under warranty they should replace it free of charge.
If not - then brace yourself for a costly exercise
Feb 23, 2008 | InFocus IN72 Multimedia Projector
InFocus IN72 Multimedia Projector Logo
176 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
