Question about Tomtom ONE GPS Receiver
My TomTom displays miles per hour about 2 - 3 mph lower than the reading on the 07 Prius/Ford speedometer. Is the TomTom correct assuming strait level road when the two are compared? Steve
How do i show my miles on my gps when i put in my routes ! i have the tom tom 3rd add
Posted on Mar 25, 2009
Touch the Screen; goto Change Preference, and then Set units; you will be able set a lot of units
Posted on Apr 05, 2008
SOURCE:
Where is the speed sensor located on a 2003 buick rendezvous
Why ? speedometer not working ? Does the vehicle shift correctly ? The VSS - vehicle speed sensor is an input to the PCM - engine computer > Speed info is sent from the PCM to the microprocessor in the instrument cluster over the class 2 serial data bus . 2003 - 2006 GM vehicles had bad step motors in the instrument cluster . Step motors control gauge position. The VSS is located on the transmission case Vehicle Speed Sensor (VSS)
Lower right rear of the engine compartment, mounted to the right side of the transaxle.
Speedometer
The instrument panel cluster (IPC) displays the vehicle speed as determined by the powertrain control module (PCM). The PCM converts the data from the vehicle speed sensor to a 4000 pulses/mile signal. The IPC uses the vehicle speed signal circuit (4000 pulses/mile), class 2 message from the PCM in order to calculate the vehicle speed. If the IPC detects a malfunction in the vehicle speed signal circuit from the PCM, the IPC uses the class 2 message from the EBCM, indicating the vehicle speed as a backup. If the speedometer reaches (108 mph) the fuel with shut-off, and it will turn back ON when the speedometer is at (106 mph). The speedometer displays either miles or kilometers as requested by the activation of the English/metric button on the driver information center (DIC). The associated indicator (km/h or mph) illuminates.
Feb 05, 2017 | Buick Cars & Trucks
How do i change the speedometer on 1998 Avalon from kilometers to miles per hour ?
install a spedometer with kilometer markings or manualy paint markings on at proper locations. 88 kph = 55 mph, etc.
if you were thinking you could push a button, not gonna happen.
Jul 01, 2014 | 1998 Toyota Avalon
2001 ford ranger speedometer needle stays on 30 mile than increases as you move
Chances are you need another speedometer, or send that one to a shop to have it fixed.
Oct 07, 2012 | 2001 Ford Ranger Regular Cab
Speedometer gives false reading after car warms up
Check that the body ground is clean and tight. I'm talking of the connection to your instrument panel. This connection be loose or corroded can make for improper impulses and incorrect readings. Lower impulses at lower speeds may be correct because it doesn't need the power as much for slower impulses. Only makes sense.
Aug 29, 2017 | 1998 Volkswagen Beetle
I have a 2003 ford escape & the digital odometer doesn't work correctly
Have the dealer do a speedometer accuracy test. They have a special tool that can electronically read the speed and then compare it to the readout of the odometer.
Jul 16, 2012 | 2003 Ford Escape
How do I change my Speedometer from MPH to KPH
If it's digital there's a button somewhere I'm sure. However if it's a printed read out, then the cluster has to be changed over...however it should also read both. This is a common issue for service men bringing vehicles back from Europe as did I in 1998. Hope this helps !
Mar 09, 2011 | 2005 Nissan 350Z
Speedometer error?
Many cars have an error on the speed indicated. 10% sounds quite high, next time you buy tyres go for one size bigger or the next profile up, eg, if you are using 70 series go to 75 or 80. That will sort your problem out and you will get better fuel consumption. You can have the speedo calibrated but I would thing that the cost or effort wonuldn't justify the result.
Feb 27, 2010 | 2002 Toyota Camry
Speedometer is 5 mph off.
Most speedometers are off by a few miles per hour even when new, this is normal
but yours could be caused by putting different size tires on the car check the owners manual for correct size tires
Mar 13, 2009 | 2007 Kia Amanti Sedan
Changing from mile per hour to km per hour
okay,for one,the odometer doesnt read in miles per hr,it reads miles driven, and two i have no idea if its possible to change the odometer to km traveled,if you're talking about the speedometer,its already there,get a european cluster :p
Jul 05, 2008 | 2003 Mazda Mazda6
Tomtom ONE GPS Receiver Logo
119 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
