I have a triton bewitch shower which keeps cutting out going from hot to cold
  • Katiana May 30, 2008
    I am having the same problem with mine, Any suggestions?
2 Suggested Answers
SOURCE:
  • 95 Answers
SOURCE: MY Triton T90si electric shower
Most conventional showers have brass seats or rubber seats that can deteriorate over time. these will leak or dribble and not maintain your temp.. Rubber and brass seats are a fairly common and easy replacement. It sure beats trying to rip out a shower valve.
Posted on Jul 11, 2008
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Buy a new shower to fit plumbing for triton bewitch
Most triton showers are compatible with each other take screws at top and bottom of cover out and see if left or right hand entry for plumbing
Sep 24, 2012 | Home
Hi, we have recently purchaed a new triton alicante shower only to find that it constantly alternates from hot to cold. the alteration is too frequent to be enjoy a shower since it wll go hot then 20odd...
try taking the handle off and moving just the stem till the right side has all cold and left side is all hot..this mite adjust the stem
Nov 22, 2010 | Home
Preasure keeps rising and falling/water gets cold and hot
This is a problem that should be looked at by a Pro. I don't know if you have a water heater or you are getting your hot water from a domestic coil on a boiler. "Your home heating unit" It is hard to give a solution to this problem without seeing it.
Jan 25, 2009 | Plumb Shop Alsons #PSB2510 Chrome...
I have a Triton topaz 100i shower, recently the water would not heat up, when i opened it the thermal cut out was in pieces, i have now replaced this, but now, no water comes out at all. If i short the...
its the thermal cut-out... when there is something like limescale that causes the temp to get over 50c - the thermal cut out is
activated... it has to be replaced... which u can buy it from triton or get an engineer out to replace it
tip... make sure u clean the shower and shower heads often with a limescale remover....
Apr 22, 2008 | Heating & Cooling
Heating & Cooling Logo
638 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
