Question about Acer Aspire 5102WLMi Notebook
Keypad hi instead of using the shift button and @ to get the @ i have to press shift and number 2 instead
  • missgfirth Apr 05, 2008
    Hi yes i know what you mean but my @ is above ' my ! is above 1 " is above 2 my pound sign is above number 3 but i cant get that either
  • 655 Answers
See on your keyboard's keys, the symbols which is above is to be pressed by holding down the shift. As ! is above 1 so for ! you have to press Shift + 1, same as @ is above 2 show for @ you have to press Shift + 2, simalarly # is above three so for # you have to press Shift + 3........... is it clear.....then... :)) ... otherwise Ask me again.
Iqbal
Posted on Apr 05, 2008
SOURCE:
My @ key isnt working. instead of that the other blue marked colan is coming. how to toggle back
Have you tried pressing the button "2" on your laptop? And have you tried pressing "Shift" and then "2"? If the number appears when pressing 2, but @ doesn't appear when pressing "Shift" and then "2", chances are your input language aren't correct. Go to Start > Control Panel > Regional and Language Options > Languages Tab. There you can set the proper input language for your keyboard.
Try using the on-screen keyboard as well. Go to Start > All Programs > Accessories > Accessibility > On-Screen Keyboard. If @ works there, then its possible your keyboard might be faulty.
Jan 30, 2013 | HP Pavilion dv6-1030us Notebook
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
How to key @ on the keyboard, only able to get " instead of @
Press the shift button while pressing the number 2 on the top row.
Mar 12, 2011 | HP CPQ175KB Keyboard
HOW DO YOU DO NEGATIVE 10 POWER NUMBERS LIKE 2.5 X10-2?
Hi ceanelson,
First, I would clear the memory. Press [SHIFT] [9] (CLR) [1](Setup) [=] (YES). Then press [SHIFT] [MODE] [2] to switch to the LineIO mode. Put the calculator in Norm2 mode. I just like the way it display these kind of numbers in Norm2 mode. Press [Shift][Mode] [8] [2] for Norm2. Next check make sure FIX mode is greater than at least 5. I usually select FIX 9 but, 5 seems to be good for must non-essential calculations. Next, press [2] [.] [5] [*10^] [(-)] [2] [=]. You can use the [SHIFT] [LOG] for the 10^ and, I usually do instead of [*10^] key.
Next, when dealing with numbers like these, I always use brackets. Such as press [ ( ] [2] [.] [5] [*10^] [(-)] [2] [ ) ] [=]. This is because, if you divide or do some other math operation you want to keep this number as a whole complete number. The calculator tends to break numbers like these up and, you do not want that to happen. It's a good habit to get into. Post a comment on any questions you may have and, I'll respond quickly.
Jan 25, 2011 | Casio fx-300ES Calculator
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
HOW TO USE THE @ BUTTON ONTHE NOTEBOOK
Press the Shift key and the 2 number key
Dec 25, 2009 | Dell Inspiron 6400 Notebook
I love my keyboard but when I press apostrophe quotes they don't appear unless I press the button twice and then I get double and have to backspace to get single quotations again.
Hi
I beleave that is how that button is supposed to work, on all the keyboards i've ever used the same thing has happened, instead I press on the " key instead of the ¨. I suppose the " is what your looking for instead of the ¨.
I'd guess your pressing on the wrong button, find the key that does " " " ", you may use SHIFT together with another key to get " to come out.
On my Finnish keyboard its SHIFT + 2 .. = "
Dec 22, 2009 | Microsoft Wireless Optical Desktop 1000...
When i press shift+2 i get " instead of this @
Press the other Shift button, OR press the ALT GR button which is the button on right from the long space bar.
So ALT GR + 2 will give you a unlimited suply of @ @ @ @ @ @@@@@@@@@@@@@@@@@@@@@@@@
Jun 18, 2009 | Dell 0Y3740 Keyboard
[email protected]
I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
Tried pressing shift and the 2 key and hey presto, I got a @.
So it looks like @ and " have swapped places.
So shift and 2 for a @!
Lizzie H
Oct 24, 2008 | Computers & Internet
Acer Aspire 5102WLMi Notebook Logo
261 people viewed this question
Ekse
Alun Cox
