Question about Invacare Pronto M51 Power Wheelchair
When should i charge batteries, should i plug in everyday even if not using my power wheel chair
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 39 Answers
No.. dont do that.. as that might weaken up your battery and ruin its battery life.. Only charge it when your using it!
Posted on May 23, 2010
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Jet 3 will not turn on but when you plug charger cord in it will light up the entire length of the battery indicator when you push the switch. Chair will still not move. Controller is a PG Drives Pilot...
the batteries are not charged and need to be replaced. The reason you have lights is because the charger is supplying power to the chair and the chair will not move when the charger is plugged in because of the inhibit function. Replace the batteries and make sure you charge before use Hope this helps
Apr 15, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I BOUGHT A USED JAZZY JET 3 ULTRA WITHOUT BATTERIES AND I HAVE BOUGHT 2 NEW BATTERIES BUT AM NOT SURE HOW THE WIRES HOOK TO THEM, IF THE 2 BATTERIES HOOK TOGETHER.
Locate the two wires from the circuit breaker attach one wire (black if marked) to the negative post of the rear battery and attach the other wire (red if marked) to the positive post of the front battery. Locate the two wires coming from the power module plug with a red and black wire. Attach the red wire to the rear battery positive post and the black wire to the front battery negative post. attach the joystick to the nine pin plug at the rear of the chair and turn it on. You should have power at the joystick and the chair should work. Disconnect the joystick put the shroud cover back on grease the seat post and reattach the seat then plug in the joystick and charger plug at the rear of the chair. Charge the batteries before use and charge them overnite for the next 20 days. If you use the chair daily charge your batteries everynite while you sleep unplug in the morning. If you don't use the chair daily charge at least once per week or after you use the chair. Always put the chair up fully charged if you are going to be out of the chair for an extended time the disconnect the batteries at the large plug going to the power module Hope this helps you
Apr 13, 2011 | Jet 3 Ultra Power Chair
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
Aug 22, 2010 | Pride Mobility Products New Pride Mobility...
Why would my less than 2 months old batteries die after 15 minutes run time?
Has your power chair been stored or not used in a while? Have you been charging the batteries regularly? Is the charger plugged in to a working electrical outlet, turned on and plugged into the power chair properly?
If the batteries have not been maintained properly, they may have become damaged that will prevent them from getting a full charge. It can happen quickly, even in as little as 1 month of storage.
When you operate the power chair is there any noise or vibration that could indicate a mechanical problem?
If you continue to have a problem, contact your dealer or manufacturer. If your insurance paid for the power chair, they may pay for repairs. Warranty may not cover repairs caused by customer neglect.
Aug 06, 2010 | Ctm HS-2800 Power Wheelchair
Sunfire power chair won't charge but lights up when plugged in
you need to have the batteries tested it is possible that if left in a discharged state for an extended time that thee batteries may be damaged and will not be able to be recharged
May 24, 2010 | Pride Mobility Products New Pride Mobility...
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Invacare Pronto M51 Power Wheelchair Logo
156 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
