Question about RCA 32V420T 32" TV
32" RCA when plugged in snaps an arcs
TV does not need to be on for this to happen. Woke up at 4am to the sound of popping and arcing- the TV was off at the time, probabley lucked out that I didn't burn the house down with family in it. Is this something I can handle? I'm a mechanic, and a so-so handy man. Could this be an easy fix or should I throw it on the garbage heap? Thanks
  • adamwes Apr 05, 2008
    just take the cap off, seal it, and put it back on?
  • 934 Answers
Normally an arc or snap like that is coming from the anode cap that attaches to the top center of the crt. The voltage there is upwards of 25k so be VERY careful if you're going to inspect this for any faults. If it is the cap leaking unplug the set and take a piece of wire attached to a screw driver with the other end of the wire attached to the grounding cable around the outer edge of the crt. Gently undo the cap from the crt and allow the blade to sit in the well for a period of time to discharge the crt completely.
Next get some HV putty, sold at most electronics distributors like Mouser and form a small ring with it. Place it around the well hole in the crt and replace the anode cap pressing firmly to seal the edges of the cap to the crt. With the back still off plug the unit in and see if that's cured the problem.
Bill
Posted on Apr 05, 2008
  • William Rayburn
    William Rayburn Apr 05, 2008
    That's about it... That should take care of it.... The discharge, although alarming isn't really a fire hazzard if it's from the anode looking for ground, but it can damage the FBT after awhile.
    Good Luck!
    Bill
I have an RCA rear projection TV MOD: D52W19B SER: E315C30GD Chassis: ITC222. The flyback arcs when power is applied, several days ago the TV was operational, a loud pop emitted from TV, I unplugged it and...
yes it is a flyback transfomer is a very sensitive piece of equipment also known as a lot or lopt in you case i would say that the case has cracked on your flyback you may get by however if the damage inside is not significant yet be wrapping the flyback transformer in black electricians tape but this should not be a permanent solution
Jan 22, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I Have A 1998 RCA Home Theatre TV Sound Works But No Picture And There Is A Snapping Sound And Light Or Ark Flashing Happening Inside
May be the high voltage lead(s) have popped off of one of the pix tubes...the flyback(HV) transformer may be defective....you can remove the rear cover and look to see what is arcing..be very careful as the voltage may be as high as 25000 Volts...if one of the anode caps has popped off, then you will first need to use an insulated screwdriver that is grounded to the chassis through one of those alligator clip jumper leads..this process will discharge the unit to make it safe to work on the HV components...then you will need to pop the anode cap back onto the tube making sure it has a good tight fit...if the problem is elsewhere, you will need to call the serviceman for repairs
Jan 08, 2011 | RCA D52W19 52" Rear Projection Television
My rca model f36669 makes a popping sound and cuts off and back on
That's hi voltage arcing. Dangerous condition were a component has broken down and is arcing causing the power supply to 'crowbar' or go into over current protection mode. Call a TV repair pro for an estimate to see if you want to keep the set.
Apr 26, 2010 | RCA F36669 36" TV
Arc in projection TV
A lot of TV's using CRT tubes have SPARK GAPS, usually on the back of the socket boards. These sometimes arc. None should continue to arc. One snap and that is it...
Dec 29, 2009 | RCA P52926 52" Rear Projection Television
RCA P52754AT POPPING SOUNDS. COLOR FLICKERS AND
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
Heard a pop like a bulb blowing and can only get the sound. it makes a crackling noise when we turn it on.
It could have a arcing Hv Block or a something arcing on the Deflection Board. If the crackling noise is louder in the rear of the set, the Deflection Board is probably the cause. You can usually confirm by removing the lower back cabinet and observing the board on the left side. If you see any arcing at all, the board needs replacing. You can call Encompass Elect. for ordering the board at 1800-638-3328.
I hope this helps,
Skyassoc
Nov 12, 2009 | RCA Scenium D40W20 40" Rear Projection...
Rca arcing and hissing
Most likely,you have a bad transformer AKA flyback ......
Is 32V420TYX6 the service # of your TV ?......Verify..........T.
Apr 05, 2008 | RCA 32V420T 32" TV
RCA PROBLEMS
two common problems with RCA TV's. It sounds like your flyback is going on you. There is probably a hole and it is arcing off a cap/ or something. You can order a new one or you can try and find where it is arcing by taking the back and looking at it in the dark to see where the arc is coming from. If you can find it try using a plastic epoxy to fill the hole
Apr 13, 2007 | RCA F32649 32" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA Guideplus Gold Television
I would guess the popping/cracking goes away when the picture is present. Sounds like a high voltage arc either withing the tube or due to a cracked component in the high voltage circuit. If it's the tube, then the question is: how old is the set and is it worth it to sink $$$ into it as opposed to putting the same into another unit. If it is a defective component, that's much easier/cheaper to repair. Again, age of the set, etc. I hope this helps; definitly a repair for a pro.
Oct 30, 2006 | RCA F32649 32" TV
RCA 32V420T 32" TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
