Question about RCA 24F512T 24" TV
How deo I play a dvd player on my rca
I have a rca tv, 4/5 years old, entertainment series, guide plus gold gemstar. It's about 30" I have hooked up a colby dvd player red-white yellow into the apporiate connectors on the back. Can't get dvd to display on scren What am I doing wrong.
  • 5 more comments
  • model-t-car Apr 05, 2008
    answere given no help what so ever.
    Do not have yellow/red cable. Have 1-yellow,1-white, 1-red, connected into video-2. Dvd on remote is to channel3. Get unusable signal message on tv.
  • model-t-car Apr 06, 2008
    Answeres don't come close to solving the problem. FixYa not worth the time and money.
  • model-t-car Apr 09, 2008
    Absolutely no help from fixal. I called a local tv tech and he resolved the problem over the phone.
    Need a refund.
  • model-t-car Apr 14, 2008
    Need a refund. Your answere was no where even close to a solution.
    Not a good answere.
  • model-t-car May 02, 2008
    Solved the problem without the aid of FixYa. You guys are from far left field with your solutions.
  • 2,322 Answers
I would suggest to select video 2 on your TV, if you have the DVD player connected to video 2 on the TV's back panel.
Make sure those cables functional as well.
Posted on Apr 08, 2008
  • 4,234 Answers
The problem is not the cable connection but the "channel" selection on the set. If the DVD is connected to the Video-2 input on the set, you must choose the video in option for the set. There are a couple of possibilities on how to do this:
1) Use the TV/Video button on either the set or remote.
2) Use Channel up to go beyond the last true channel to get to the video or Aux channel.
The other alternative to connect a DVD is to use an RF converter. This will take the Red/White/Yel combination and convert to an RF connection that will allow you to see the DVD on either channel 3 or 4.
I hope this help to clear things up.
Dan
  • ABRsvcs May 02, 2008
    I have sent a note to our contact at Fixya requesting that your refund be processed. Would you please be so kind and post the actual resolution to your problem. It may be helpful to others.
    Thanks,
    Dan
  • RCA Master
  • 19,396 Answers
Use scart if you can
Posted on Apr 05, 2008
  • 2 more comments
  • Ginko
    Ginko Apr 05, 2008
    Use scart connector, your tv should have one. By using scart your tv will display dvd automatically each time you press play on dvd. Using the av cables you have more troubles, as you need to select explicitly the input/output from dvd and tv.
  • Ginko
    Ginko Apr 05, 2008
    You need to use the scart cable, the yellow red cable is used mainly to connect other devices. Just do it , and it will work.
  • Ginko
    Ginko Apr 05, 2008
    Yes tey are white, red and yellow (yellow is video, rest is audio) they are composite audio video cables also called rca cables or s-video/audio cables, there is not much to say about connecting the tv using composite cables.
    To use them (the yellow plug is video, the red and white plugs, audio): Plug in composite cables to the outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
    If they do not work either you are doing the connection wrong, or is a faulty cable or your tv does not support the signal in output from dvd. In this case, unless you have a particular need for using RCA cables, I will suggest using a SCART, that usually always work.
  • Ginko
    Ginko Apr 05, 2008
Hooking up dvd player
I searched everywhere i could think of for a manual or a diagram of the back of the player with no luck - any chance you can post back a photo of the back of the dvd player, then we can easily talk you through what to connect to what and what cables to use. :)
Jun 27, 2007 | Oritron DVD600 DVD Player
Rca truflat guide plus gold gemstar tv problems with built in dvd player
Check and replace the optical pickup unit of this set. It is faulty.
Aug 19, 2012 | RCA TruFlat 27F520T 27" TV
32" RCA Entertainment Series, Guide
Probably not. RCA parts for this model are very difficult to find. Even you could find a kit, it will not have enough to repair. A do it yourselfer or TV tech will have a difficult time repairing this. Please shop for a new TV. Thanks for asking and show a few hands of support!
Mar 21, 2011 | RCA Televison & Video
My t.v. whines when innitially plugged in. no picture (rca f36650) guide plus gemstar xbox ready entertainment series
The tv have a dead part call the FBT-Flyback transformer,a big black block of plastice with a red wire with a black cap hook it to the CRT-(Tv picture tube).The FBT-give the tv highvoltages to the CRT(Tv picture tube).This tv is old model of an analog tv probally can't find part for it anymore.
Dec 08, 2010 | RCA F36650 36" TV
Volume broke
yes. unplug. wait 2 minutes, plug back in. turn on. with factory remote control for tv press.....menu, 7, 1, go-back, tv....... easy
Nov 13, 2009 | RCA Televison & Video
RCA Guide Plus Gold Gemstar 27 inch Entertainment Series has perfect picture no sound. The speakers are ok have tested them. When tv is turned on and dvd player is on shows perfect picture but can only...
On the left hand side of the remote control there is a blue or diferent kind of small sercle round buton (mute) push it once and turn the volume up till you hear the volume.
Nov 06, 2009 | RCA Televison & Video
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at ninalashua@yahoo.com
Jul 09, 2009 | RCA 32F531T 32" TV
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
RCA 24F512T 24" TV Logo
163 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
