Question about Sony Ericsson S710a
Signal problem i have signal problem sometimes even though i'm near at the network
    President:
  • 1,017 Answers
It could be a number of things causing this. The network is failing, the phone is behind a metal screen/grid. The contact between one half of the phone and the other is damaged.
"Confucius he Say: A girl's best asset is her lieability."
Posted on Apr 10, 2008
Htc sensation has no signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 12, 2012 | HTC Sensation 4G
My mobile has a special problem. The mobile shows a weak signal and sometimes zero signal at my home even though the other nokia mobile signals are very high at my home.(same network other nokia mobile...
Are they the same models?
The phone's capability to sustain a stable network coverage may vary even in model types.
While at your home,remove the phone's battery and simcard and fit them again.
Note how the phone's network signal registers.
It may start very high and then drop drasticaly to very low or no signal at all or sustain a constant signal reception.
If the reception's good in other areas,then your home area's network coverage may not be that good.
Hope this helps.Thanks!
Oct 31, 2011 | Nokia Cell Phones
I have really poor signal most of the time, sometimes it's "emergency calls only" for no apparent reason, sometimes it says the GPRS is detached, sometimes there's just no bars even though i'm...
Are you using an old SIM card? Sometimes a worn out SIM card won't make a solid connection with the metal contacts, resulting in a drop in signal strength.
You might want to look into getting a new SIM from your carrier, and see if that helps.
Otherwise, I am guessing it is a hardware problem with the phone itself.
Mar 01, 2011 | Sony Ericsson P1i
My ps3 keeps losing playstation network and sometimes can't find a network even though it's showing wi-fi at 100% signal strength.
What you should do is you should buy an Ethernet cable from a shop a shop like staples. Basically what this is is that it is a wire that you have to connect from you console to your modem, which will give you good internet connection and will hopefully work.
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
Weak singal
plz change your mobile set
Jun 13, 2009 | Nokia 5200 Cellular Phone
Does't connect to network - search Network
Hi
It sounds like you may have a poor 3G reception in your area. Even though other O2 phones are working better they may be running on the 2G masts in your area.
Try in setting/network menu turning off 3G reception, that way the device will only look for 2G masts. Your handset will give priority to 3G masts where available and sometimes will hold onto the weakest signal making poor call quality, and or dropping connection.
Advantages to using 2G only = better standby and talk time / better reception where 3G is poor.
Disadvantages = Slower web browsing / no video calls.
WEP / WPA will only apply if you are connecting using WI FI and have nothing to do with your mobile network connection.
Hope that helps?
Apr 27, 2009 | O2 XDA Flame Smartphone
How to remove the color blue H symbol near the antenna/signal
The H means you can access high speed internet. To turn it off, Settings>Connectivity>Mobile networks>GSM/3G networks>GSM only.
Hope this helps.
Mar 30, 2009 | Sony Ericsson Walkman W902i Cell Phone
No signal
Your phone's signal may depend on the reception provided by your network provider, like for example...if you are near to one of your network provider's cell site or transmitter, you can get stronger signal for your phone...else, you'll have a weaker signal or reception..specially if your location while using your phone is in a remote area and no cell site or transmitter nearby.
Oct 17, 2008 | Sanyo SCP-3100 Cellular Phone
Wireless connection in dell laptop
have you installed the driver for the wireless ?
May 13, 2008 | Dell Latitude D600 Notebook
Sony Ericsson S710a Logo
42 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
