Question about Amana AKT3040 Electric Cooktop
Burner light does not go off on Amana AKT3040
I have an Amana AKT3040 and when I installed it one of the burner lights in the set of four in the middle of the unit always stays on. All four light will work when the burners are on but this one light never goes out even after the burners have cooled down. Also, when I turn on one of the knobs white smoke came out around the sides of the knob. It would go away when the knob was turned off.
I had the exact same two problems with my AKT3040. Both problems were on the dual burner.
1. Problem with the "hot" light always ON was solved by replacing the burner (problem caused by defective temperature sensor), unfortunatley it seems you can't get the sensor by itself these days so I had to change the whole burner.
2. smoke came out from the knob controlling the dual burner: problem solved by replacing by a new knob. You have to be carefull since the replacement knob is a little different than the original part so you have to connect everything properly as per the provided instruction sheet.
Posted on Aug 08, 2008
  • 135 Answers
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Posted on Apr 07, 2008
No burners work
Do you have power? Check to make sure the power cord is plugged in. Check for a reset button where it's plugged in to the wall. (It may be tripped). Check your breaker box for a tripped switch.
Apr 09, 2014 | Amana AKT3040 Electric Cooktop
What should the burner placement look like
If it's a four burner cooktop chances are there are two the Same one bigger and one smaller. Usually they only fit one way
Mar 05, 2014 | Amana AKS3040 Gas Cooktop
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
Jul 20, 2010 | Amana AKS3040 Gas Cooktop
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
We have a smooth electric cooktop and the burner that has the option of being large or small only lights up small. What part do we need to fix this?
first check the wiring to the burner itself you might have a burnt connection to the larger one or a bad receptacle if both are good then you would have to buy a new burner try allbrands appliance parts they seem to be cheaper
Apr 30, 2010 | Amana AKT3040 Electric Cooktop
My amana model AKT3040 is making a loud "pow" when i turn it on with a white flash under the glass, then the breaker trips. It is 6 years old this month, not under warrenty, Should i try to get a repair...
Amana will confirm this - but I am fairly sure that the elements under the glass are replaceable. Most units by other manufacturers are repairable...but if yours is not, then careful shopping around will save a ton on parts cost.
Labor will vary by market...but it is typically better to have the replacement part when contacting a repair service.
Oh, yes, the snap is a broken burner element. the breaker trips because the resistance on a shorted element is insufficient - and the current draw becomes excessiver - popping the breaker.
Nov 06, 2009 | Amana AKT3040 Electric Cooktop
Electric cooktop burner is always on hi when it's on
I just wanted the name of the part and possible sources. Not worth paying $14 for.
I found it else where.
You should give your prices up front, before users spend any time trying to use your site.
Jun 10, 2009 | Amana AKT3040 Electric Cooktop
Multiple burners turning on
You have wires that have melted and fused together giving you the result that you describe. If you are mechanically inclined you can make the repairs yourself, if not, hire a pro as you can get a serious shock. Get back and let me know how you make out.
May 20, 2009 | Amana AKT3040 Electric Cooktop
Gas burner not getting enough gas
It sounds like a bad pressure regulator. Or it may be adjusted for LP gas. I need more information. Sometimes you can adjust it yourself, sometimes you need to buy a kit or new regulator.
May 18, 2008 | Cooktops
Amana AKT3040 Electric Cooktop Logo
388 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Ted Maxwell
Paul Carew
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
