Question about Car Audio & Video
Car radio Hi,Thanks for you'r contact.some more info for you.radio 6000RDS. switch on".Locked"press 1&6 button screen flashes DP MV 5H.. 50 7000 12.. 07-02-00 255 Touch any button Locked comes up on screen. Many thanks..
  • 3,037 Answers
Q
Have you tried with failed attempts at all? I found this about the radio
I know I have the correct code but the radio does not do anything when I try to enter it.
A It is likely someone has tried to enter a code or accidentally entered a number by pressing the radio preset station buttons. Most radios will enforce a delay between code entry attempts which increases (doubles in some cases) with every try. These radios need to be left switched-on, completely untouched, until they are ready to accept the correct code. Others give a maximum number of attempts - usually 10 to 13 tries after which the radio must be decoded.
Blaupunkt radios will often enforce a delay of 1 hour between code entry attempts during which time be careful not to press any keys or the 1 hour waiting period begins again. The display should change after the hour, indicating it is ready to take the code.
I will keep seeing if there is anything else that you can do
Posted on Apr 05, 2008
  • Benjamin Patri
    Benjamin Patri Apr 05, 2008
    you can try holding down button 6 for 30 - 60 sec and see if that does anything first
What to do when the Panasonic DP-8020E Black and White Copiergreen light and the red light are blinking at the same time on a
Hi
One of two possibilities. No 1 it could be that the paperlift motor is faulty and does not lift the paper tray uo, thus not detecting paper.
in this case you will need to contact your service agent for a repair or replacement.
Should the red spanner light also be lit it could mean that the fuser needs to be reset. This is done by going into the service mode : Press and hold function, original size and 3 buttons in that order. you should see F1 on the screen. press the 9 button and the start button. scroll down to ram initialize and press start. scroll down to LBP Fuser reset and press start. press 1 for yes. switch machine off wait and switch machine on again.
should the problem persist contact your service agent.
hope it helped
Aug 19, 2014 | Panasonic DP-8020E Black and White Copier
Unlock ford car radio. have code.
can you give the number or name of the model
Apr 05, 2008 | Car Audio & Video
What is my radio code
No, the items you're seeing displayed are part of a self-test mode in the radio. I can generate the unlock code, but I would have to have the serial number from the radio. Getting the serial will require you to pull the radio out from the dash, but you shouldn't have to disconnect anything. It will be located on a small sticker either on the back or the bottom of the stereo.
Aug 15, 2014 | Cars & Trucks
Car radio code for ford ka
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Aug 21, 2012 | Car Audio & Video
How do i get service code alert off my nissan tinos screen please its not on the list Nissan Tino
Hi there.I think i can help u to turn off service alert, Its done in the following way:-
1.Switch ignition on ( do not start engine )
2.Switch radio ON.
3.Start engine.
4.Switch radio OFF.
5.Press and hold INFO button.
6.Turn volume control knob at least 30 clicks until self dianostic menu is displayed and an audible
signal is heard. ( while still holding the INFO button )
8.Using the circular dial ( Joystick ) select Confirmation/Adjustment and press centre of joystick
to ENTER.
9.Select Service and press ENTER.
10.Select Reset and press ENTER
11Press BACK button to return to main menu.
12.Switch OFF ignition
This should do the job, sorry it`s so long winded
Good luck John ( South Wales UK)
Aug 02, 2011 | Nissan Altima Cars & Trucks
I need the key code for FORD MONDEO 6000 CD RDS EON and ford mondeo 2001 model engine no CHBA1B41415A. If possible.
then it comes dp mv 5H then it comes 09--00--00 does anyone have the code for this plz my email is khhove@hotmail.com
Jan 28, 2011 | Car Audio & Video
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
Fault with my ford 6000rds stereo
Put the right plug in right site.
Feb 22, 2008 | Audio Players & Recorders
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
L/O wont turn off
do a search for the manual online..... there are tons of sites out there with scanner info.
Aug 24, 2007 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
Car Audio & Video Logo
181 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
