Question about Whirlpool LEB6200 Electric Dryer
Whirlpool dryer The dryer is smelling hot and the clothes was very hot in it. we waited a couple of hours and tried to turn it back on, however it wouldn't come on, and we checked the breakers and they are fine. What could the problem be.
  • 481 Answers
It could be a bad limit switch (metal thermostat) that turns the heat off when getting too hot. if the heat continues too much it will burn out a "fuse" in the back of the machine and it will not turn back on. so if you replace the "fuse" then make sure you replace the limit switches too or the "fuse" will burn out again.
Posted on Jul 05, 2008
Have a whirlpool dryer type dwsr ele 2406026-cv54 / mod wed4900xvo , we get a burning smell on all items
  1. Ok, bare with me...
    Is there any visible SMOKE with the smell? If so turn it off and call a repairman.
  2. Verify that the clothes drum is turning freely. If it is not, call a repairman.
  3. Otherwise;
    I recommend removing all clothing from your dryer and to carefully follow these instructions.
  4. With the machine off, Clean the dryer filter well. Set dryer to the MAXIMUM heat setting on a 30 min TIMED cycle.
  5. Start the cycle.
  6. Make close observations in short intervals of time.
  7. At the end of your timed cycle determine if the smell has changed more or less.
  8. With the dryer off, Locate the electrical socket/plug of the device if it is an electric machine. place your hand on it to determine it's temperature. It should be no more than Luke-warm to touch.
  9. If it is uncomfortably warm to touch you should consider contacting an electrician to determine the working load of the wiring to the device.
  10. If the wiring/plug test is deemed adequately cool, ventilate the dyer area well for an hour and repeat steps 3-7, the hot - empty test again. The smell should diminish.
Lint and other clothes debris can get pulled into contact with the dryer's heating element and it will burn or smolder. If a piece of elastic rubber gets into contact with the heating element, the smell will be strong and may last a long time.
If it is still bothersome after the burn-out procedure, it will have to be taken apart and at least cleaned or the element replaced. This is not usually covered by warranty as it is considered a USER PROBLEM. Sorry.
Mar 29, 2017 | Whirlpool Dryers
Dryer smells like it's burning
You probably have lint build up in the lint houing, you need to clean dryer by take dryer apart ,you may need to call services tech.
Feb 18, 2015 | Whirlpool Dryers
Clothes smell burnt after drying
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 10, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
It is taking over 2 hours to dry a load of clothes. I stopped the cycle and opened the door to check the clothes. The dryer smelled like something was burning but no visible smoke. This is a fairly new...
Sounds like the vent is clogged with lint. You should have the vent cleaned once a year to keep the appliance operating properly. Also, make sure there are no kinks in the vent line.
liberty
Jan 20, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer smells like sulfur . The clothes smell
Run a couple of hot washes with no clothes in the machine
Before you do dissolve some Soda Crystals in 2 liters of hot water and put them into the machine by hand.
Your machine smells because new powders wash at lower settings and do not contain bleaches and soda to kill off the grease which is washed off the clothes
Jun 16, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
Mar 15, 2009 | Whirlpool LER5636P Electric Dryer
DRYER RUNS ABOUT 15 MINUTES, HEAT WORKS,MAKES NOISE AND STOPS
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
gdhi64
Feb 13, 2009 | Whirlpool LGR5636L Gas Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Whirlpool LEB6200 Electric Dryer Logo
83 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
