Question about Baby Gear
COSCO SCENERA 22123-DDZ STRAP PLACEMENT
NEED PICS ON HOW TO ADJUST STRAPS AFTER CLEANING
  • 1 more comment
  • discpixy May 09, 2008
    cannot replace straps and they are not secure. cannot figure it out. cannot make them long enough for the largest adjustment size.
  • Anonymous Aug 21, 2008
    I took it apart, and am having trouble putting the strap w/tension mechanism back on. I should have written it down ... Can anyone help me? I wish I still had the manual.
  • innerharbor Nov 23, 2008
    Washed the fabric and now can not figure out how to place the straps.
3 Suggested Answers
SOURCE:
  • 48 Answers
SOURCE: Need instruction manual
i will email you, i have the manual for the exact car seat only in the brown / black patttern
Posted on Aug 19, 2008
  • 4 Answers
Hi Guys,
Just found this - as i had the same problem!
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614D.pdf
Hope it helps!
Posted on Jul 01, 2009
What does cosco scenera model 22216-llp
You should see a harness strap over each shoulder that goes though the shell, behind the seat, and connects to a metal splitter plate.
The front of the harnesses (2) extend down though the buckle tongues then into the hip area of the seat.
There is a crotch strap that comes out of the shell where the child\'s crotch is. The buckle is attached to this strap.
There will be a LATCH (Lower Anchors and Tethers for Children) strap that goes through one of two belt paths. If used, this strap must go though the proper belt path.
Finally, there is a top tether strap the comes from the back of the seat - near the top - that will attach to the tether anchor in your car (see your car owner\'s manual)
My suggestion to you is to purchase a new seat. The protection of your child is most important.
Jul 10, 2014 | Baby Gear
How do we put belts thru and attach the brass latch on the back of the cosco scenera convertible transatlantic?? a pic of the bk of car seat would be helpful..
Here is the pic you requested. I am going to link to where I got it from as there was an issue (not a recall) with the harness getting cuts in it and I would like you to be aware of it. Being a parent I know how important those straps are. Hope this helps. http://www.car-seat.org/showthread.php?t=48028
Mar 21, 2011 | Cosco Juvenile Scenera Convertible Car...
How do you attach the cup holder
In the box were there nails for you to build the seat and attch it
Aug 21, 2009 | Cosco Juvenile Scenera Convertible - 22123
Cant get cosco scenera model 22123 RMD car seat back together
http://www.coscojuvenile.com/usa/eng/DJGFiles/ProductDocuments/43583614E%20-%20US%20Scenera.pdf
Pages 40-46
Jul 27, 2009 | Cosco Juvenile Scenera Convertible Car...
Having trouble with straps in car seat
Bring the straps up through the holes on the bottom of the seat, one on each side. The metal plate on the end should pull in flat and snug against the plastic. Slide the buckle pieces back on, making sure they're facing the right direction to snap in. Slide the chest clip back onto both straps.
Place the ends of the straps through the slots you want the harness at (at or below the child's shoulders for rear-facing, at or above the shoulder's for forward facing), making sure that they don't twist. Pull them down low behind the seat.
The adjuster part of the strap has a kind of Y shaped metal plate - pull it up to meet the ends of your straps, making sure that it
doesn't twist, either.
There are loops at the end of the harness straps. Feed the curved part of the Y through the loop of the strap that's on the same side of the seat. Pull it all the way through, so that the fatter part on the ends of the metal plate are exposed and curve around a bit beyond the strap so that it doesn't slip back off. Do the same with the other side.
Now adjust the harness to fit your child. When it's tightened properly, you should not be able to pinch up any slack, lengthwise, at the hips or shoulders, and it should lie in a straight line down the front, with no drooping. Also adjust the chest clip - it should lie even with your child's armpits - not up in the neck, and not over the belly, where it can't do it's job properly. (It's job is to hold the straps over the center of the shoulders...if it's over the belly, they're likely to slip down off of the shoulders in an accident or sudden stop and also poses the danger of internal injuries.)
One other thing - car seat harnesses should never be submerged in water, as it can damage and weaken the webbing. They should only cleaned with a damp rag. If you put your harness in water when you washed the rest of the seat, I'd strongly recommend contacting Cosco (contact info here) to order a replacement harness.
Dec 30, 2008 | Cosco Juvenile Scenera Convertible Car...
Cosco Car Seat Model Number 22123 Instruction Manual
need instructions ASAP on how to put back together the straps, I took off the cover to wash it. It is NOT EASY to put back.
thanks,
yolanda
Sep 17, 2008 | Baby Gear
Baby Gear Logo
779 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
