Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
  • 5 more comments
  • Anonymous Jun 25, 2008
    same problem this evening started to over heat and lights melted light ficture
  • hiboom Jul 02, 2008
    Same problem and Sears wants to handle it as a regular service call ($65 to look at it).
  • Anonymous Aug 01, 2008
    same problem this evening started to over heat and lights melted light fixture, the warranty is not valid because it three past the warranty period!
  • Anonymous Aug 11, 2008
    Exact same problem with mine. Now, when you say Sears has a fix for it, does that mean the $ service plus parts and labor? Or they make a free correction to a known problem? My refridge is 1 1/2 old and past warrenty naturally!
  • rikoshet Aug 20, 2008
    have the same problem. I removed whole thing with lights. COuld I fix by my-selves?
  • Anonymous Aug 26, 2008
    Same problem, same model refrig. Last night light stayed on even though doors are closed and freezer, melted light assembly, ruined food. What part(s) needs replaced, other than the light assembly - part# 6621JK2003B. Does this really require a home service ($109) just to get a dianosis and estimate? They won't even bring the parts. Claim there is no Sears service bulletin about this problem.
  • Oregon1426 Aug 28, 2008
    Yep, We had the same problem happen this morning. We had to unscrew the bulbs - not a very satisfactory solution, but at least we can use the crazy thing. I find it hard to believe that there is no service bulletin if this as common as it sounds.
    An expert whose answer gotĀ voted for 100 times.
  • 210 Answers
This is a problem, there is a relay on the board that is sticking. Unscrew your lights or it will melt the display and possibly the liner. There is a fix available, contact Sears they should have a service bulletin out for it.
Sgt 48
Posted on Jun 27, 2008
Have to slam freezer door to clear 88 error codes on samsung refrigerator
I am not certain on this, but my guess is that you have a problem with the door closed sensor, which should be attached to the door/ light actuating button. It may be faulty, or just out of adjustment. I assume that you have contacted Samsung about what error code 88 is. Do they have any other input? What doesn't make sense is that the fridge turns off. You would think that if the door sensor read "Open door" it would continuously run, rather than shutting off, unless it is causing an overload, or overheating condition. I have had good luck w/ Samsung tech dept., but they can be a little hard to reach. Hope this helps.
Mar 10, 2014 | Refrigerators
Fridge working intermittently.
i guess there is some problem with the thermostat
get it changed.....
Oct 08, 2008 | Refrigerators
MF12568aes "door open" light keeps beeping when all doors are shut
Wipe down the contact area on the door and corresponding area of the inside of the fridge. if this doesn't work, there is a faulty connection to the sensor inside the refrigerator that will require a service call. Not something a lay person should attempt to repair, as trying to fix yourself will probably void any remaining warrantee on the item. Good luck
Jan 23, 2013 | Maytag Refrigerators
My Samsung Cool' n Cool Fridge Freezer it wont stop beeping. The doors are both shut and the appliance is switched on. I have accidently broken the little plastic mechanisim that opens and closes upon...
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
Aug 31, 2011 | Refrigerators
I got new replacement doors for my fridge and now when I close the doors the lights wont shut off. this is my second set. The original door lights worked fine. what is wrong?
The original doors contained a hidden trigger that turned the lights off.
You need to retrieve this trigger from the old doors and fit it to the new doors
Mar 31, 2011 | Electrolux EI23BC51IS
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
179 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
