Question about Maytag MMV5186A Microwave Oven
Non-working microwave Although the light comes on and the timer works for the requested cook time, the actual microwave action is nil. It worked fine and then it didn't. I have unplugged and replugged. Is there a reset button, fuse, transistor or some small thing I can do to make it work? It's 5 years old.
  • sscot002 Apr 20, 2009
    my microwave just did the exact same thing and it is about 5 years old Maytag model #MMV418AAW 1000 watts
  • klevenow May 01, 2009
    Lights go on, timer works, timer counts down as if the unit is working, tho' the cooking motor is NOT running.  Worked fine, then ceased.
    6 years old.  No problems at all prior to this.
    HELP???
  • Maytag Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 08, 2008
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
Microwave will not work
Even though you don't mention the model number, you posted under Sharp model R-1491, so I'll assume that's it.
You say when trying to work the actual microwave, you get nothing?
We could use a little clarification, but FixYa only gives you one shot at posting a help request.
When you enter the cooking time and press "Start", if the timer counts down and the oven lamp comes on, but the the turntable, cooling fan, and microwave section do not run, then you have a bad secondary interlock (bottom door switch) or its mount is bad.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
Also look at this info on door switch diagnosis and replacement.
Hope this helps.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 30, 2010 | Sharp R-1491 Microwave Oven
Will only defrost, and not cook on high
What is the make and model number?
Eric
Jun 21, 2009 | Microwave Ovens
Whirlpool microwave only cooks for limited time?
It's possible that the module that produces the microwaves is failing. The parts are cheaper but the labor may not so get an estimate before deciding if it's worth repairing or replacing.
Nov 20, 2017 | Whirlpool GH5184XPQ Microwave Oven
Set control board to cook and not working
you have a bad door switch, check for burns on the switches and connectors, if not its the pc board
Jan 09, 2009 | GE JVM1631 Microwave Oven
Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work fine, and the light inside turns on. We can enter a cook time, and it counts down as if...
It's one of the micro-switches (3) that are part of the interlocking safety circuit. I actually took my switch apart and fixed it, but 99% of those out there would (and should) replace the switch.
Dec 28, 2008 | GE JVM1330BW/WW Microwave Oven
Only 1 function works at a time on mco16
That actually sounds like correct operation in that you cannot use the timer while it's cooking.
Assuming yours is model number is MCO160S, you can download your owner's manual here if you don't have it.
Page 19 tells you how to replace the cooktop lights and the cavity light.
Dec 13, 2008 | Magic Chef CMV1000B Microwave Oven
Maytag MMV5186A Microwave Oven Logo
186 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
