Question about HP Pavilion dv6000z Notebook
Again hep me
My problem is when window xp starts automatically stack .
so what is the solution for this
thank you for your helping
    Problem Solver:
  • 11 Answers
Just try to reboot the machine,the press F8 when the prompt comes the choose safe moode,the moment you enters windows desktop then reboot the machine. if it won't boot again then just repair winXP OS It will solve the problem for you.
epamost@yahoo.com
Mr CPU......
Posted on Apr 07, 2008
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Unable to start bluetooth stack service
Computer services are found under computer management:
Click start, right click computer and click manage. At the bottom of the computer management window click services and applications, in the main window double click services. Look down the list for your bluetooth service, right cllick and cllick properties. Look for startup type, click the dropdown menu and choose automatic and then cllick start, just below. Click apply and then ok to close window. Restart the machine and see if issue is resolved.
Mar 18, 2012 | Computers & Internet
How do i set up bluetooth connectivity
If you have Windows XP with Service Pack 2 or 3 installed on the computer, then the computer has the Microsoft Bluetooth Protocol Stack. The Microsoft stack allows you to install an external Bluetooth adapter automatically. If the Bluetooth adapter supports the Microsoft stack but it does not install automatically, then you do not have the Microsoft stack on the computer.
>>Make sure that you have installed the HP All-in-One software on the computer.
>>Attach an HP Bluetooth adapter to the front USB port of the HP All-in-One.
>>If you are using an external Bluetooth adapter for the computer, make sure the computer is on and then attach the Bluetooth adapter to a USB port on the computer. If you have Windows XP with Service Pack 2 or 3 installed, the Bluetooth drivers are installed automatically. If you are prompted to select a Bluetooth profile, select HCRP.
On the Windows taskbar, click Start , and then click Printers and Faxes .
>>Double-click the Add Printer icon.
>>Click Next , and then select A Bluetooth Printer .
>>Follow the onscreen instructions to finish the installation.
>>Print as you would to any printer.
Regards
Riztech.
Mar 31, 2010 | HP Photosmart C6180 All-In-One InkJet...
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Windows XP - need to restart Wireless Zero Configuration
type this in command window sc config wzcsvc start= auto
Oct 07, 2009 | Microsoft Windows Xp Home Edition Sp2...
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
I m not able to install win xp sp2 on my compaq notebook
windows xp cant detect ur hdd bcoz its SATA hdd.
Solutions:
1. Install vista instead of XP
2. You need to disable this SATA feature in BIOS to install OS.
SATA disable steps.
1. Restart the computer and start tapping F10 key.
2. Choose System Configuration tab.
3. Disable SATA native support.
4. Save and Exit the BIOS by pressing F10 key
Aug 21, 2008 | HP Compaq Presario V5000Z Notebook
How to connect wire less connection with my laptop,
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Aug 11, 2008 | Linksys WRT300N Wireless Router
HP Pavilion dv6000z Notebook Logo
87 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
