Question about Panasonic Lumix DMC-FX8 Digital Camera
Shutter the shutter wont close
    Problem Solver:
  • 19 Answers
Do you really mean the shutter? Or do you mean the lens barrier? The lens barrier opens in front of the lens when you go to take a photo.
Assuming it is the lens barrier which is stuck open, the cause is usually dust/grit. A series of "puffs" with a large bulbed blower, e.g.a Giotto, should help clear it.
If it's been caused by liquid ("coke" is a favourite!) then the sugar is holding it open. A little (very little) ethyl alcohol dropped on the lens and allowed to percolate around the barrier area should sort it.
If it is the shutter you mean, then that is a workshop job.
Posted on Apr 05, 2008
I have a Minolta XG-A camera, and i can take a picture but the shutter is stuck?
My shutter does that when there is low light, or just slow shutter speed. You could try changing those settings, otherwise, last time mine got stuck, I loosened a screw on the bottom right under the shutter release button and the shutter just snapped back into its place.
Jun 09, 2012 | Minolta XG-A 35mm SLR Camera
The shutter wont open or close
Try resetting the camera by removing the battery for 20 mins. then replace the battery go to the camera's menu and set the Date and Time.
May 28, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Shutter wont close
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
May 16, 2010 | Pentax Program Plus 35mm SLR Camera
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
Can view pics, shutsdown in camera mode, shutter wont close
lens assembly is bad must be replaced to make it work again .
Apr 14, 2009 | Cameras
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Memory card shutter wont close
Try closing it with the card removed.
If it will will not close shut, this suggests a piece of plastic has broken off.
The quick fix is gaffer tape it shut.
Indeed it is likely the only fix unless the camera is still under warranty, whereupon it will be replaced
Nov 30, 2008 | Polaroid A500 Digital Camera
Shutter not closing when taking photo
Try to take video or take picture in dark conditions. If video records correctly, then the CCD sensor is broken. Contact HP and ask if they would repair it for free.
Nov 07, 2008 | HP Photosmart R707 Digital Camera
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
Feb 17, 2008 | Nikon F80 35mm SLR Camera
Panasonic Lumix DMC-FX8 Digital Camera Logo
388 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
