Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Frigidaire dishwasher will not start. Light flashing.
My fridgidaire  built-in stainless steel dishwasher wont start. The "washing" light continues to flash even when I tried to leave it on overnight. Th latch is clicking shut all the way. I have also tried running the sink o get the water hot and I dont believe that is the problem. The light just flashes and no water cycles. Thanks for your help.
  • 4 more comments
  • Anonymous Jun 04, 2008
    I pushed the ultimate scrub cycle and tryed to push the start button. All that flashes is the 99
  • Anonymous Jul 16, 2008
    Exact same problem as first poster.
  • Anonymous Aug 08, 2008
    Mine is doing the exact same thing. We had a power outage, and now it doesn't start, even though it worked fine just hours before.
  • Anonymous Sep 06, 2008
    I'm having the exact same problem. Multiple lights on my frigidaire are flashing, the power has been back on for days but the dishwasher will not do anything. It also doesn't help that the model number is impossible to find, so I can't locate an exact user manual online. :(
  • jimyork Oct 28, 2008
    EXACT same problem. It's stainless as well. Only a couple of months old.
  • sixxshot Nov 24, 2008
    Frigidaire dishwasher model # GLD2250RDC3 we lost power and dishwasher would not work. washing light would flash but nothing would happen. three weeks later it worked fine for about 2 weeks now all lights are flashing and nothing happens. help!
SOURCE:
  • 58 Answers
SOURCE: Frigidaire Dishwasher Console/Lights Flashing
which light flashes?
Posted on Nov 02, 2007
  • 1003 Answers
SOURCE: Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
CHECK DRIVE MOTOR OR BELT OR TIMER
Posted on Jan 18, 2008
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
Posted on Jan 28, 2009
SOURCE: Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
Posted on Mar 28, 2009
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
My frigidaire gallery series dishwasher wont start and the lights are flashing. whats wrong?
I would cut the power to it for a full 5 minutes and see if it resets itself???????
Feb 10, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
I press the start button and the washing light just blinks nothing else happens
Sounds like a faulty latch...the dishwasher thinks that the door is open, so it just keeps flashing the lights until it's closed. I'd order and replace the latch
Mar 30, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Washing indicators light is flashing and dishwasher won`t start
try to start again while applying closing pressure {push in} at the top of door where latch mechanism is if it starts then it's an adjustment that needs to be done on the door latch
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
BUT!
Happy Washing!
Feb 13, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher, flashing lights, frigidaire
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire gallery dishwasher fdb949gfb2
it looks as tho.you have a touchpad problem.the touchpad is malfuntioning.
Jun 25, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
735 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
