Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer
Electrical and or burning smell coming from washer
  • Anonymous Apr 11, 2008
    We had the same problem and needed a new motor.
  • louis082 Jun 28, 2008
    I have a whirlpool washer and the motor coupling went out of it so fixed it. Now when it runs it smells hot.
Had the same problem it needed a new water pump and belts and pulleys to the tune of $368.00 dollars
Posted on Jul 12, 2008
Posted on Apr 11, 2008
3 Suggested Answers
  • 464 Answers
SOURCE: Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Posted on Oct 25, 2009
sonicboomele
  • 1557 Answers
SOURCE: Maytag Atlantis washing machine (MDE8600AYW) just
black soot is a sighn of electrical burn off get maytag back out and demand they fix it (the only time a gearbox needs replacing is when there is oil leak present)
Posted on Jul 04, 2010
Maytag Atlantis washing machine (MDE8600AYW) just developed an electrical burning smell. Transmission recently replaced by Maytag. Black soot under appliance.
Jul 04, 2010 | Washing Machines
I can smell rubber burning and the washer no longer works. It will not turn-on at all.
Handyman here -
If it sounds like it turns on, but doesn't move then it could be a drive belt or the transmission.
If it doesn't sound like its turning on, then its probably the computer board.
From the 'burning rubber' smell, I would bet on a belt.
Apr 03, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't do anything but fill.
It is very likely that the motor has burned out. What happens is that the water solenoid allows water to fill to a certain point where a fill sensor stops it. The program then moves on to activate the motor which will agitate the wash. So when power is supplied to the motor, it tries to start, overheats because of a break down of insulation in the windings, and you smell burning. Replace the motor.
Nov 18, 2009 | Maytag Atlantis MAV6260AWW Top Load Washer
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
MAV Atlantis 6000
hi. thanks for the question .the clicking sound is something caught, in water pump. the rubber smell is the belt . pull washer away from the wall. small door at the back left corner ,remove pump on the floor. remove 3 3/8 bolts remove. replace . belt underneath washer . replace thanks the appliance doc please rate me
Aug 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
267 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
