Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
"My Book" folder shuts down when I use it.
Hi
Whenever I enter the My Book external harddisk, I get an windows error that closes the folder. The error messages states: "Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. I have considered sending the error report to microsoft although I am not sure that will help.
  • 30 Answers
try to install the drive on another USB Port.
Cheers,
Posted on Apr 11, 2008
SOURCE:
Windows 7 problem
try to connect the usb HDD in windows with safe mode(by pressing F8 while booting ) and try to check the HDD system disk by windows tool, this might solve some errors. and restart ur device & can work normally then, if windows found errors on ur harddisk & fixed them. good luck
Dec 25, 2011 | Microsoft Windows 7 Ultimate 32 bit Full...
Tip
How to Restore Disabled Folder Pane in Windows Explorer
Problem:
When you open Windows Explorer, the left hand Folders pane is disabled or gray or blank and the folder tree on left is not available.
Cause:
There may be an error in the registry. A required system file is missing or an incorrect version.
Solutions:
Close Windows Explorer.
Start the Registry Editor (click Start, Run, type regedit and click OK).
Expand HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
In the right-hand pane, locate the value named ExplorerBar. If present, delete it.
Restart Windows Explorer. If this does not resolve the issue,
The correct solution depends on the version of Internet Explorer that is installed on the computer.Internet Explorer 5.5 or lower
The preferred solution for computers with Internet Explorer 5.5 or lower is to upgrade to the latest version of Internet Explorer.
If this is not possible:
Open the folder C:\Windows\System. Check that the file browseui.dll is present. If it is not present, restore this file.
Internet Explorer 6
Open the folder C:\Windows\System. Check that the file shdocvw.dll is present. If it is not present, restore this file.
Open a command prompt.
Enter the command cd \Windows\System
Verify that the command prompt shows C:\Windows\System.
Enter the command regsvr32 /i shdocvw.dll.
Enter the command regsvr32 /i browseui.dll.
A message will appear confirming the successful registration of the files.
Now restart the sytem and confirm the problem is solved.
on Jan 17, 2010 | Computers & Internet
Error 8e5e0155
Hi. To rule out your browser's settings as the cause of the issue, please optimize it.
To optimize Internet Explorer:
http://windowslivehelp.com/solutions/accounts/archive/2009/03/03/How-to-optimize-Internet-Explorer-browser.aspx
Hope I helped MSN expert Dr Reed
Sep 01, 2009 | Microsoft Windows Live Messanger
The device Generic Volume cannot be stopped right now. try stopping the device again later. on Window XP
If you tried to stop your external hard drive with it open in Windows Explorer, You will get this message. You cannot disconnect the drive in this condition. Even if you close Windows Explorer after, Windows still thinks it is open. The best thing to do, is restart Windows and when the screen goes black, shut the power off to the external drive or disconnect the USB cable. Disconnecting in any other way causes Windows to have problems with USB devices in the future.
Jun 08, 2009 | Western Digital 500GB My Book World...
Explorer.exe Application error
Hi bj_bhuvnesh,
 Whenever internet explorer crashed, you would see the overwritten message.The best option would be to upgrade the browser if you are not using IE 8. You can also copy or format and again install the windows. Create a back up and than format the drive in which you have installed windows files.
Check the below mentioned :-
http://www.worldstart.com/tips/tips.php/2683
Thanks for using Fixya.
Apr 26, 2009 | Microsoft Windows XP Professional
I get the error message 1327 invalid drive G:\ when trying to download and install any software on my computer. The question is - I DO have a external hard drive that opens with the G:\ drive but, it has...
I don't know if this is the right way to fix this but: I realized that G is the drive letter given to my external drive. All I did was plug it in so the computer could "find a drive G:\" and it worked great!
Dec 23, 2008 | Computers & Internet
Windows explorer
Bring up the Start Menu, click on Run. Type Command and hit Enter.
In this command windows type
chkdsk /f /x d:
This will run a disk integrity check of this partition and see if there aren't crosslinked file entries, which has a 50 50 chance of being your problem.
Restart when done and see if this is resolved.
If it isn't comment back to this thread and we'll take it to the next step.
Regards,
Worlvet
Nov 17, 2008 | Microsoft Windows Vista Ultimate Edition
How to create "Message Stores" in Winfax Pro 10
To create the message store folder: 1. Close WinFax and the WinFax Controller. 2. If you are running Windows NT, 2000, or XP, stop the WinFax service. If you don't know how to do this, read the document How to start or stop a service in Windows. 3. Using Windows Explorer, locate and then double-click the Symantec WinFax Pro folder. 4. Click File. 5. Point to New, and then click Folder. 6. Give the new folder a name (My Faxes, for example) and press Enter. 7. Close Windows Explorer.
Jul 31, 2007 | Symantec WinFax Pro for PC
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
107 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
