I GET A BLACK LINE ON THE SCREEN OF MY PLASMA TV
  • benharmer Apr 05, 2008
    I HAVE A BLACK LINE ON MY PLASMA TV SCREEN IT HAS BEEN TURNED OFF AND ON WITH PLUGS IN AND OUT BUT THIS LINE IS STILL THERE ITS ABOUT AN INCH WIDE AND GOES FROM THE TOP TO THE BOTTOM OF THE SCREEN
    THE LINE IS STILL THERE COULD THIS PROBLEM BE ANY OF THE CONNECTIONS TO THE SCREEN
    Genius:
  • 3,422 Answers
This is a serious problem. It may be a design problem or a defect in the video processing. Since it is temperature related..... or digital error buildup of some kind - it is not an easy one to diagnose without some hands-on observations and measurements.
A tech will have to put on an oscilliscope and trace through the circuits and find out where the vertical bar is being introduced. These sets are grossly complicated from a circuits point of view with several IC chips that make it difficult to troubleshoot. If the TV warranty gets to it, they may replace the main board or the display driver or whatever is producing the malfunction.
But, I believe strongly it is a manufacturers warranty problem and they should be held to it. Make sure they realize it has been going on for before the warranty expired and you have not been able to get their attention.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO:Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
THREE:The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If the problem still persists then like i said before,you will have to get it repaired by a technician.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 05, 2008
  • Priya darshan Apr 05, 2008
    Was that comment for me?
    Genius:
  • 1,447 Answers
Try to turn off unit, let it cool for a few minutes and turn it back on without a cable or devices attach to it. If the black line still appears then there might be a problem with the unit it self, if there is non then chances are you need to make sure that cables are tightly plugin to your tv.
Update me for results, thanks!!
  • 796 Answers
May be there is some problem in the transistors on the screen
  • isaac johny
    isaac johny Apr 05, 2008
    The plasma display screen is made of a matrix of elements
    connected to cables along the side and top. On your unit, some of
    these many, tiny connections are making contact intermittantly thus
    losing the elements in that area. These contacts are held in
    place with just pressure and if that is disturbed, you lose that line
    of elements.
SOURCE:
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Thin black line across screen of plasma tv
lines on a plasma tv can be cause by a few different things. One of your buffers might be bad. The logic board might be bad. Or your tv screen coldu be bad. The only way to find out is by replacing the boards or the screen.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung 50 in. Plasma TV
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black line on plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 19, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
3 Black vertical lines on my Gateway Plasma TV
i just fixed my gateway 42"plasma with the exact problem.  go to this link, and read entirely and follow!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 30, 2008 | Televison & Video
Plasma screen
this plasma TV repair site might have the fix if the lines are black thick ones. bad circuit joints that might need to be re-soldered.
Jul 24, 2008 | Samsung PPM42S3 42 in. Plasma Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Ekse
