MY PRINTER DOES NOT LABEL IT'S Pages - Office Equipment & Supplies
    Genius:
  • 1,447 Answers
What application are you printing from? Basically its the software that handles these features
Try this:
Please try the following:
1. Have your document up on your screen.
2. Click on "INSERT" "PAGE NUMBERS".
3. Select the options you prefer (as header or footer), (right, left, center, inside outside, etc.).
4. Make sure that these page numbers are not outside of the printable area or margin area.
If you are placing the page numbers as a footer:
1. Click on "FILE" "PRINT".
2. Click on "PROPERTIES".
3. Click on the "PAPER" tab.
4. Choose "MAXIMUM".
5. Click on "YES".
This will enlarge your printable area so that you can set your bottom margin as small as .12 inches. This will help in printing the page numbers as a footer.
If this does not resolve your issue, please contact Microsoft for further assistance. This particular issue is software related.
Posted on Apr 05, 2008
SOURCE:
Troubleshoot tec barcode printer
Download windows driver from www.bartenderbarcodesoftware.com
define the pages et label size in the driver, check that you have validated the coreect use (direct or thermal transfer) gap, black mark etc..
Once the driver install , you can use ssdal send file.txt to snd a file to the printer. Check with the help /? option
Nov 21, 2013 | Toshiba TEC B-472 Thermal Label Printer
Desktop out for repairs. Moved 420 label printer to laptop area. Have copy of label file from desktop. Can't get the labels into the laptop printer and it's not in FAQ that I can find. Really need to make...
Microsft Word is probably not only the best but if not the only solution. Test print a label or two, at a time and then a sheet, at a time. Attempting to print muliple sheets from a file associated with a different, standard, printer may not line up well enough to print pages and pages, unattended.
What you see between these ---> < - > <---- Brackets are actions for you to perform.
You'll may wish to choose a Microsft Word Template, you can do that by opening Microsoft Word, <Help>, <Tempates> or (if you cannot find templates) via: http://office.microsoft.com/en-us/templates/ select a label from your file and pick the number from the list that corresponds with the label on the box of labels. Please forgive the ambiguity, I'm working blind without knowing your Operating System or your version of Word, what printer, etc... This is general enough for most systems.
Here's the order:
  1. Click <Tools>, <Letters and Mailings>, Click <Envelopes and Labels>.
  2. Click the <Labels> tab, and Click <Options>.
  3. First choose the printer you want to use and next the label supplier number from the box sheets that you'll print your labels on.
  4. Click <Product Number>, scroll to the corresponding number from the label box. click Ok
  5. Click <Envelopes and Labels>, Click <New Document> and a label document will open.
  6. Type data onto the labels you choose to use, Avery number work well with Word .
  7. Click <File>, Click <Print>.
Now, you could try to make a copy of your label list, to experiment with, but it's probably best that you re-type the labels into each of the boxes while reading from your label program; until your PC is returned
Mar 11, 2011 | Seiko Instruments Smart Label Printer 420...
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Zebra s4m is printing blank pages
turn printer off, press pause buton, tur on, wait 5 secunds and relese the button. He goin to print the test label, Pause. check Darkness seting, ajust if necessery. don't forget to save. To go out from the test, turn printer off and on again.
the ribbon is on the correct way?
The labels are Termal Transfer and you don't have ribbon in the printer.
Jul 02, 2010 | Zebra S4M Thermal Label Printer
Will my 2600 make labels
Yes, you have to choose the label feature within Word though.
Label feature in Word: http://www.worldlabel.com/Pages/word.htm
Jan 08, 2010 | Lexmark X2600 InkJet Printer
Replaced cartridge on HP P3005 printer with OEM model 51A but still get message "Order cartridge less than 100 pages."
there is 3 different ways to solve this:
1. remove cartridge and replace it again
2. you have problem whit cartridge e-label (printer can't "read" it) - replace cartridge
3. E-label reader is dirty or broken...bad, visit HP authorized service
Nov 10, 2009 | HP LaserJet P3005 Printer
My printer won't print. It will only produce blank pages.
Usually that means that the labels are missing from the printer. Turn the printer off. Reload the label stock and restart the computer it is connected to. Then it should work properly.
Apr 14, 2009 | Zebra Z6M Plus Thermal Label Printer
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
Cd lables
matching the label template is essential to the actual labels, especially when using generic cd label slicks/pages.
start with printer driver updates here
Feb 02, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Open Questions:
146 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
