Question about Motorola Mobility MPx220 Pocket PC
Does not start
When i turn on my mpx220 there is just a motorola logo on display. iz wont do anything. what can i do?
  • HUrrego Sep 24, 2008
    I tryed to change the regional settings on my MPX220 and it required me to restarted i did so and it wont start,, all i get is a white screen with a motorolla sign in the middle of it,, is there anything I can do to fix it???
  • Anonymous Mar 06, 2009
    i have an MPX220  about 1 year old.......it worked properly for a period of 8-10 mounths but suddenly one day it stopped switching on .........if i switch iton it is hanging at that motorola logo................can i get done with this problem......................
Change the rom or hard reset,to do hard reset first press the big blue button and hold it press and then press the power swich,the message master reset will apear and choose yes.By doing this you will loose everything on your phone
Posted on May 05, 2008
SOURCE:
Hi my name is Carla.I have a motorola mpx220, the
Carla,
Those friends are right in saying so. Your firmware has got corrupted and needs replacement. Please go to the service center of motorola and get it done.
Feb 11, 2010 | Motorola Mobility MPx220
My MPx220 seems to be **** in flight mode no keys will work
When the back cover of the battery is removed it automatically goes into flight mode. Most likely the little plastic tab that pokes into the slot where the switch is could be broken? You can manually poke it down with a pin or paper clip and replace the back.
May 11, 2009 | Motorola Mobility MPx220
Where to buy motorola mpx22o flex cable
you can purchse motorola mpx220 flex cable in delhi nehru place.
Jan 13, 2009 | Motorola Mobility MPx220
Motorla MPX220 Screen turning Red
where you got the flex cable from.....
Nov 03, 2008 | Motorola Mobility MPx220
Motorola mpx220
First try a other battery from a friend with the same phone, if the problem is solved, the battery is faulty, If the problem is not solved, the battery connector is faulty, you will have to take your phone to a repairman to have this repaired. Hope this helps Regards
Aug 07, 2007 | Motorola Mobility MPx220
FLIGHT MODE
start and home button in the same time (when the phone is turned ON)... than select OFF to flight Mode.
May 03, 2007 | Motorola Mobility MPx220 Pocket PC
How to reset my phone?
YOU COULD TRY THE MASTER RESET. INSTRUCTIONS....[1]TURN OFF THE PHONE [2]PRESS AND HOLD DOWN THE BLUE BUTTON AND WHILE PRESSING THE ON BUTTON. [3] THE PHONE WILL ASK IF YOU WANT TO MASTER RESET CLICK ;YES' OK. TRY YOUR LUCK.
Apr 24, 2007 | Motorola Mobility MPx220
My MPX220 internal LCD broke
I would personally suggest going to ebay. They carry many replacement parts for cell phones such as the Flex cable that you need, and are quite inexpensive as well. I guess figuring out how to install it is the tricky part. Good Luck!!!!
Feb 11, 2007 | Motorola Mobility MPx220
Open Questions:
BULLGUARD TeCH SuPpoRT pHoNe {^}+^/18OO8O\^\31O69^/= NuMbEr ddkkjj Usa BULLGUARD USA phone number is ranked #2 out of 2 because 7,728 BULLGUARD USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the BULLGUARD USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BULLGUARD USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BULLGUARD USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BULLGUARD USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BULLGUARD USA Calling BULLGUARD USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BULLGUARD USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BULLGUARD USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BULLGUARD USA's phone numbers against each other. Contacting BULLGUARD USA in General While I8OO8O31O69 is BULLGUARD USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BULLGUARD USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BULLGUARD USA.
Oct 17, 2019 | Best Computers & Internet
See all Motorola Mobility MPx220 Pocket PC Questions
Motorola Mobility MPx220 Pocket PC Logo
237 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
