Question about Hoover U6616-900 WindTunnel Bagless Upright Vacuum
Self propelled cable
I can see that the cable is broken that controls the self propelled motor. But I can't figure out how to remove the the top cover that will give me access to repair. Any thoughts?
  • Jacob Malone Apr 19, 2008
    I also have a broken cable (or one that has come loose) and cannot find a manual to describe how to get to the lower end of the cable to make the repair.
  • Anonymous May 11, 2008
    My cable is frayed and broken too. Seems that this is a weak spot on this vacuum.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=491150
Self propelled cable (by 2 users)
Posted by raider84 on Apr 05, 2008
I can see that the cable is broken that controls the self propelled motor. But I can't figure out how to remove the top cover that will give me access to repair. Any thoughts?
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by Dr_Jake, posted on Apr 19, 2008 I also have a broken cable (or one that has come loose) and cannot find a manual to describe how to get to the lower end of the cable to make the repair. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I would contact either the local vac dealer or to contact the Hoover Factory or Manufacturer to get the owner’s manual to get an exploded view of the self propelled cable or have the email or fax the information that you need, but they should be able to send you an owner’s manual so you can try to fix it yourself. You don’t want to exceed the repairs cost to the price of what you paid for it. The decision should be yours, example: if the repairs costs are $200.00 and you paid $279.99 then @ that point you would have to decide if the repair costs are worth or do you want to pay the lower cost of repair and continue on. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 07, 2008
Control cable broke push and pull broke
Remove the handle assembly by removing screws and sliding off. Remove nozzle housing cover and unscrew fastener at end of cable. Pull cable from handle end out of cable sheath. Slide new cable into sheath and fasten at bottom as it was before. You will need to adjust the cable to the proper location so the transmission works properly in both directions.
Apr 18, 2014 | Hoover Self-Propelled WindTunnel Bagless...
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Drive not working on my hover sweeper handle seems very loose
How to Change Actuator on Hoover Self-Propel vacuum Cleaner - Step by Step This is a notorious problem for the Hoover WindTunnel Self-Propelled Models. What happpens is that the handle of the vacuum that controls the transmission is controlled by an actuator arm that is attached to a cable that runs down through the machine. The poor design of this self propelled system is design in such a way that if you pick up the vacuum using the handle (this is natural way to do it, I'm guilty of this as well), it puts too much strain on the actuator arm that controls the self-propelled mechanism, and causes the nut, washer, and screw to strip right out of the actuator arm. This explains why your handle is so loose. You may verify this by looking at the gap between the upright body, and the lower agitator housing, right where the vacuum pivots when you step on the handle release pedal. You should see when you move the handle up and down that the cable and nut are the only parts moving, and you should be able to see where the nut did sit inside of the actuator arm before it was stripped. The good news is that this is a relatively inexpensive part, and the repair is really not that difficult.
I will explain step by step, and include pictures so that you may see how to replace the part that's broken.
Always be sure your vacuum is unplugged from the electrical outlet before performing any kind of service!
Tools and materials:
Torx bit or driver size T-25
Flat blade screwdriver
Phillips screwdriver
Actuator arm – Hoover part number 43143046
Here's the picture of the part that probably needs to be replaced.
Step 1. Place your vacuum cleaner upside down with handle resting on the floor and brush roll housing resting on a work bench.
Remove 4 screws from rug plate and set rug plate aside.
Step 2.
Remove power drive belt, brush roll belt and brush roll.
Step 4.
Remove 6 screws as shown. Also remove duct hose cover and small plastic section that was under brush roll in upper left corner.
Step 5.
Place vacuum right side up on top of work bench with handle all the way back. Using a flat blade screwdriver; gently pry the top cover away from the bottom housing in the area shown by(#1) arrows. Leave the 2 adjustment knobs(#2) in place.
Step 6. If the self-propel adjustment cable HAS NOT broken away from the actuator arm, proceed as follows; mark the position of the cable(#1) in relation to the cable retainer with a black magic marker to avoid having to readjust the cable position. Remove the screw(#2) (usually a Torx T-25 size screw) and cable retainer. Next, using a flat blade screwdriver; slide the ‘C’ ring (#3) off the metal post. Bend the metal bracket up off the post just enough so you can lift the damaged actuator up and off the post. Slide your new actuator arm back over the metal post. Slide the ‘C’ ring back over the post.Lock the self- propel cable back in place with screw and retainer. Test to ensure the power drive is adjusted correctly; CAUTION, YOU ARE ABOUT TO COME VERY CLOSE TO MOVING MACHINERY, NO NECKTIES, NECKLACES, LOOSE SHIRT TAILS,UNACCOUNTED FOR TOOLS OR CLUMSY FINGERS ARE ALLOWED FOR THIS NEXT STEP!!! Reinstall the power drive belt, plug your vacuum cleaner back in and turn it on. Check to make sure the handle is in the neutral position; observe that the power drive is NOT moving. Push the handle slightly forward. You should see the power drive wheels move in the forward position. Pull the handle back, you should see the power drive wheels move in the reverse position. Some finer adjustment may be necessary.
If the power drive cable has broken away from the old actuator; just try to get the new actuator arm as straight as possible. Using the handle and while observing the cable moving back and forth through the retainer area; move the cable all the way forward, then pull it all the back, try to gauge where the middle of the forward and reverse position would be and lock the cable down. Perform testing procedure as in previous paragraph. Again, some fine readjustment may be necessary.
I hope that this was helpful. I'm am 99% sure that this will fix your problem, but if for any reason it doesn't, please feel free to use the Clarification Request Form here on Fixya, and explain why this didn't work. Please feel free to logon to our website, http://www.govacuum.com/ if you need any parts for your Windtunnel.
If you can't find a particular part, more then likely we have it, just feel free to give us a call.
If this repair was hepful to you please be sure to rate the repair as helpful by clicking the Thumbs Up Icons in the top right hand corner.
Thanks again,
Chris J.
GoVacuum
Mar 27, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Self-propelled WindTunnel U6436-900 cable
the belt could be broken. check the belt for the drive system.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self-propelled Broken?
I have the same problem, found out there is a cable that is broken, I'm trying to figure out how to fix it.
Aug 11, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel upright self propelled. U6473-900. Brush does not work. Heard it was a 'brush controller' problem and can be fixed. Please tell me how.
Most likely the flat belt has stretched enough so as to not turn the pulley that in turn turns the brush roll using a V belt. Also there is a small idler wheel, if hook up, then it won't engage the V belt.
May 20, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Self propell feature not working
You can order the lever for the transmission on line for about $16.00. It comes as a cable and lever assembly. I just took the top cover off and replaced the lever without doing the cable. The reason ours broke is because we lifted the vacuum by the handle without the self propel bing turned off, this pulls on the actuator and breaks it.
Oct 28, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6616-900 WindTunnel Bagless Upright Vacuum Logo
238 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
