RELIANCE ELECTRIC WATER HEATER Logo
Posted on May 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New water heater installed in Jan.2010, first no hot water at all, replaced top element have hot water now but reset button trips and have to reset it when all hot water is used. Any ideas what is wrong?
Anonymous
Level 2:
Scholar:
  • Expert 102 Answers
  • Posted on May 22, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
102
Questions
0
Helped
39192
Points
131
The reset switch works like a thermostatic breaker and although unusual, it is possible the reset switch is bad or weak. You can replace the reset but some are hard to find. It may be easier to replace the upper thermostat with reset. I would also suggest that you check with the vender you purchased it from, and relay your story to them as they may be willing to help you with the parts. I hope this helps.
1helpful
We have a reliance 600 about 4 years old. Recently when you turn on the hot water you get a lot of air out of the line. Also the other day we had scorching hot water and then no hot water. We reset the...
1) Reliance 606 Electric water heater, AO Smith subsidiary.
Good brand.
Copy following links:
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
2) First: Test elements using cheap multimeter from hardware store.
Next: If elements test OK, then replace both thermostats.
3) If that doesn't solve problem, then add comment Jan 2013 and report what you find.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Same sears 66 gallon water heater keeps resetting button after replacing both upper and lower theremostats and elements
1) Live answer Jan 2013.
Read why ECO trips and scroll down and read ECO keeps tripping:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#ECO
Check that thermostats are sitting flat against tank.
Look and smell for signs of burning.
Check watt rating printed on end of new element matches watt rating that shows on label on side of tank
Make sure factory-installed installed insulation is put back over thermostat and element to avoid cool room temps from affecting thermostat.
Test wires.
http://waterheatertimer.org/How-to-test-water-heater-wires.html
Make sure tank is wired correctly.
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Add comment and say what you discover
Water heater
Guessing that you have 240Volt residential non-simultaneous electric water heater? And that you have 30 amp breaker and 10 gauge wire. And that water heater is located within 100 feet of breaker box. And there are no leaks running hot water out of tank. And that you installed fully brand NEW elements of same wattage as old elements. And that fully brand new thermostats were installed, and wiring exactly duplicates wiring that was present before. And that factory-insulation was re-installed over elements and thermostats.
1) Guessing the 'hot water shut off' means the ECO red reset button located on upper thermostat keeps tripping and cutting off electric power to water heater?
2) If the ECO is tripping, then water is getting too hot, or there is shorted wire located near the upper thermostat, .
Typically replacing both thermostats and replacing elements will solve this problem .... assuming that new thermostats and elements are good, and wiring correct.
Double-Check your wiring on upper and lower thermostats.
Test wires for short.
Make sure factory-insulation is re-installed over thermostats so cool room temperature will not affect temperature reading.
Check that thermostats sit flat against steel tank.
Many short draws hot water can also cause stacking event that will trip circuit breaker.
3) Add comment and say what you find using checklist above.
Be careful to explain findings fully, using same words found on links above, so illuminated diagnosis can be made.
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
2answers
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
No heat the water.
Suddenly no hot water: Red reset button tripped, circuit breaker tripped, bad upper element, bad thermostat, loose wire, TP valve is running hot water out of tank, leaking faucet is running hot water out of tank.
1) Check for leaks.
2) Check circuit breaker.
3) Open top cover on water heater and push in red reset button.
If reset is popped out and will not reset, replace thermostat:
4) Test upper element:
5) Loose wire
Do full troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
2answers
It has cold water comign out no hot
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
We installed a brand new Reliance Electric Hot Water Heater, but no hot water, only lukewarm! Replaced top heating element and still no hot water!! Any suggestions as to what we need to do now?
If you have some hot water from dual-element water heater, then that tells us:
Water heater is 240Volt.
Upper element is working. If upper element is not working, then heater has NO hot water.
Reset button is not tripped.
Electricity and breaker to water heater are delivering 240Volts to heater.
Remaining suspects are:
1) Bad upper or lower thermostat: Solution: replace both thermostats for 28$.
2) Bad lower element: Solution test and replace element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3) Loose wire or loose connection: Solution: open both covers and inspect for burning. Tighten all screws very tight.
4) Bad wire: Solution: Buy cheap multimeter from Home Center and do a 30 minute troubleshoot of entire water heater before replacing any parts:
When testing for voltage, rotate multimeter dial to 240-250-277VAC
When testing elements or continuity, rotate multimeter dial to Ohms.
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Replace thermostat and heater element get to hot have to reset
Your question is a bit hard to understand.
You need to replace elements and thermostats because water heater is tripping reset button.
Make sure you put factory insulation back in place after working on water heater, or the heater can overheat and trip reset button.
Here's how to replace electric water heater thermostats:
Here's how to replace water heater elements (except for Rheem bolt-in elements)
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If heater still has problems, add a comment
Top Reliance Water Heaters Experts
john h
Paul Carew
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
