Question about Canon ZR100 Mini DV Digital Camcorder
Minitape will not eject
I got the famous "remove tape" message on my ZR100. Problem is that the tape will not eject. Any suggestions?
On another forum here, the suggestion was that you wrap on the screen side of the camera with your knuckles. This method absolutely has proven to work on three ZR100's I have for the school I work at.
Try it yourself and see.
Posted on Apr 30, 2008
SOURCE:
Every time i put a tape in to play or record, it keeps ejecting it why??
Please be more specific. When you insert tape, the tape housing extract to its body, or it just stays still and eject your tape.
Aug 15, 2010 | Canon ZR100 Mini DV Digital Camcorder
Tip
Remove tape issue
I just rec'd. a response from Canon in regards to my recent issue that you are all having with tapes being ejected, not loading. I was told that the issue was due to the many different tape manufacturers using different types of lubricants for their tapes. These lubricants can build up on the head and cause the tape eject issues. They suggest trying a dry cassette cleaner, but as my camera will not even accept a tape that option is not viable. I will try using denatured alcohol on an electronic swab (large q-tip available at Radio Shack) and try cleaning the head. I will keep you all posted on the results. Also Canon said that the posts can be loose and this will also cause problems. I noticed someone else had similar concerns this also something I am exploring and will keep you up to date on.
on Dec 28, 2007 | Canon ZR100 Mini DV Digital Camcorder
Tape is stuck in cannon zr 100 camera and will not eject
There should be a manual eject button. You know like on CD-ROM's there was a small whole for a paperclip to fit into, there should be one on that camera. This will eject manual, and becareful the tape might be caught on the head.
Nov 09, 2009 | Canon ZR100 Mini DV Digital Camcorder
Tape will not eject / Battery full
while the eject process is trying to happen remove the battery and replace it. keep initiating the eject process and removing the battery and it should finally eject. If you attempt to use the camera again put in a new tape so you don't lose a tape that contains footage you may want to save.
Dec 07, 2008 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR100 cassette compartment won't open
Usually a chime happens when you open the plastic cover just before it opens. If you plug it into the electrical outlet does it eject that way?
Jul 06, 2008 | Canon ZR100 Mini DV Digital Camcorder
Zr100 tape stuck
TAKE IT TO NEAREST SERVICE CENTER TO FIX THE PROBLEM. NO WAY TO REMOVE THE TAPE MANUALY
Dec 03, 2007 | Canon ZR100 Mini DV Digital Camcorder
Tape wouldn't eject, now power unavailable.
open it. find the motor that activates the tape door. turn it by hand until tape is fully exposed to be removed.
May 31, 2007 | Canon ZR100 Mini DV Digital Camcorder
No power and unable to eject the tape
check the small fuse in the power supply if you can open the your camera...indicate letter k and n at the power supply section...
Oct 15, 2006 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
222 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
