Question about Nokia 6288 Cellular Phone
Phone cannot get past nokia opening scene
I turn my phone on and it goes past the enter pin and opening scene, But that is as far as i get all that happens after this is a white screen with the battery logo in the top left hand corner, this then stays for aprox 5 mins then goes off
  • Meg809 Apr 14, 2008
    mine does the same sort of. whenever i used 2 turn it off and then back on again it would take a really long time for it to reboot. ive had the problem before and took it to get it fixed, it worked perfectly for a short while. then it started being slow again. and a couple of days ago i turned my phone off and when i tried turning it back on it got stuck in a loop. going to that white screen to the normal screen where it says menu, making me think the phone was ready to use, but then it would go blank, and the white screen would pop up again. the nokia 6288 is a piece of ****.
    Sergeant:
  • 218 Answers
It sounds like it is a problem from Viruses or the memory card is fully loaded nif it is so then erase the unwanted data and leave 15% to 20% space atleast
Posted on May 09, 2008
I had changed my nokia c3 security code some days back. i forgot the password. can you help me? the phone is locked now.
Hi ther here is some steps if it works..Enter the last four digits of your phone number on your cell phone PIN screen.
Enter 9999, and if that doesn't work try 1111, and if that doesn't work try other four-digit numbers you may have entered.
Shut off your cell phone, take off the back of your phone and pull out the battery. Record the IMEI number which is under the battery. Re-insert the battery and power on the phone. Enter the last four digits of the IMEI number on the PIN entry screen
Call your service provider and request the unlock PIN if none of your attempts so far have worked. You will have to prove you are a customer by stating your cell phone number..
Finally See a cellphone technician..
Jun 19, 2011 | Nokia C3 Cell Phone
My pincode is blocked and it is asking puk number so i called to my customer care which is idea and then i enterd the puk no. and then it is asking new pincode no.,i enterd sum 4 didit no,and now it is...
Just follow the instruction carefully as what the phone is asking.
Here is the steps :
If you got error lately,just turn off you mobile for 1 hour to reset the counter,cause if you continue entering wrong codes,the seem might be rejected or it goes like "simcard rejected
* turn on your mobile (mobile should be off for 1 hour to reset the counter)
* if ask for the PUK code,enter it
* If ask for a "NEW" PIN code,enter your new desired PIN code
* If ask to verify the code,just retype your new desired PIN code.
Hope this will help you... good luck...
Jun 12, 2011 | Nokia C3 Cell Phone
Pairing to nokia 6700
both party A and B blue tooth should be on
from nokia 6700. go to settings , connectivity , blue tooth open . turn on blue tooth . and scan .. click on the party B ( buddy phone ) confirm the name from the other person whom u want to pair and then sent a req ( it ll be asking for pin. use any pin of your choice i.e 123 and the party B ll be prompt for a pairing n enter pin. he must enter the same pin u have put in on your phone before sending a req, it ll be done
Feb 21, 2010 | Nokia 6300 Cellular Phone
Nokia reset PIN
Hey welcome to fixya. Hope u 'll be fine
  • First of Go in your settings of phone
  • Now open "Security" option
  • There first option 'll be " Pin code request"
  • Open it and on it
  • It 'll demand your first pin code request. Enter 12345 there
  • It 'll be on
  • Now goback the 6th option 'll be "Access Codes". Open it.
  • There 'll be a second option "Change Pin code" it it again demand first the pin code then enter again 12345. Then Set a new pin code which u want,
Enjoy
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
& Keep using Fixya
Feb 12, 2010 | Nokia 6300 Cellular Phone
My phone is locked
You Have To Call Your Phone Company Been There Done That lol.
Jan 04, 2009 | Nokia 6230
Security code Nokia 3110 classic
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
Apr 17, 2008 | Nokia 3110 Cellular Phone
I need my 4 digit id code b 4 i can get my puk number but i forgot it
you have to phone 07973100450 from a land line. it will ask you for your phone number a few times then it will pass you to  a REAL person who will ask you ask you a few security questions like what are the last four numbers of your top-up card and vol lia that is how you get your four digit id code!!!!!!!
Feb 22, 2008 | Nokia N73 Cellular Phone
I've tired to set the PIN code for my Nokia 6085 phone but I cannot. I've entered the PUK code but now it says, "Enter new PIN code:" What do I do? I've entered a code I wanted and other ones on my...
hi
as youve entered the puk code, it asks for the new pin code, the default code was 1234 right? so if you are going to try the new pin code yu can either invent a new pin code or just enter the default code.
hope this helps.
Jan 24, 2008 | Nokia N73 Cellular Phone
My phone have PIN code blocked
You should get your PUK number from your service provider... no one else have it
Dec 28, 2007 | Nokia N95 Cellular Phone
Resetting PIN on Nokia 6070
Most codes on phones have a generic code of "0000" or "1234" or "123456". try that as the PUK code. If not, contact the manufacture and they can give you the unlock code.
May 22, 2007 | Nokia Mirafone OP201 Phone
Nokia 6288 Cellular Phone Logo
76 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
