Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Black wont print
My MFC 240c brother printer wont print in black. I ran the self cleaning 5 times and it still wont print black any ideas as to how to fix this.
vince
  • 1 more comment
  • vinnythemole Apr 19, 2008
    Hey thank you for your help it didn t fix it but i appreciate you helping me
    Vince
  • vinnythemole Apr 21, 2008
    Hey I tried your advice a couple more times and the printer gave me a real light showing of black. Than I cleaned it over and over and used an entire cartrige of of ink of all my ink colors but my printer finally works good again thanks for the help
  • Anonymous Apr 25, 2009
    remove air bubble from black ink, mfc240
    black ink, not working.. did cleaning already
  • 832 Answers
Sure. if you re lucky the generic ink hasn t destroyed the ph bk channel yet:
use skyhorse carts (http://www.skyhorse.net.cn ) who built good and reliable carts with a very good ink quality!
To get bk again:
press menu tehn start bk copy then fourtimes arrow up. machines will
be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts, refresh all tubes and ph channels with fesh ink and eliminates the air bubbles (quite a big prob within brother inkjet printers). When finished press 7 -6 -3 to
run a power purge. leave the maintenance mode by pressing 9 then 9. do run a test print.
If you cant see ANY bk the ph is clogged and cant be fixed any more. it needs replacing then.
Posted on Apr 05, 2008
SOURCE:
When I test print, I do not get a full pattern of black dashes. I changed ink cartridges and have the same result. The color test prints are fine
If you are missing dots it is due to the print head not the cartridge.
Try doing a self cleaning a few times (max of 5) by pressing "ink" and select "cleaning"
If after 5 cleanings there's still a problem, you may need to have the printer serviced or replaced.
Since you're still getting most of your dots though, I think the cleanings should clear it out.
Thanks,
Pat
Mar 31, 2010 | Brother Multi-Function Center MFC-240C...
My Brother MFC-240C printer is causing me grief. It prints out in black as though it is out of black ink but the ink is full. The other colors print out ok. Any thougths?
If the colors print OK, you could try cleaning the black nozzles. (Your machine may allow you to clean just the black or the colors, or all the nozzles).
1) Press the <Ink> or <Ink management> key
2) Use <Up> or <Down> arrows to navigate to "Cleaning" and press <OK>
3) Use <Up> or <Down> arrows to navigate to color that needs cleaning, or "All" and press <OK>
4) The display will show "Cleaning" and "Please wait"
5) After completion, the printer should be ready
If the problem persists, brother advises that you may need to repeat the process up to four times. If still no results, contact brother customer service.
Jan 22, 2010 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC 240C printer that will not print black ink. I just changed all the cartridges. All the other cartridges print. I ran the clean cycle many times. No error messages just blank paper.
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother MFC 240C All-In-One InkJet Printer
Black ink in brother 240c printer does not print new cartridge
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc260c problems
Hey sd19,
Try getting a kit of new Ink for your printer. It isn't your Hard/Software, it is the ink that is causing this, you may have black ink in it, but it may not be injecting. If you insert a new ink kit, it should work fine.
hope this helped -CA
Nov 09, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC-210C won't print
I have cleaned, retested and new ink and it still will not print Black
Jul 11, 2008 | Brother Multi-Function Center MFC-240C...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
349 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
