Question about E-Machines eMachines Desktop PC
Emachine not responding
I'm trying to fix a broken computer that my dad gave me. When I first plugged it in and turned it on it worked normally so I couldn't work out why my dad said that it was not working. A few minutes late I noticed that the power light was no longer on, after that it will not switch on at all.
I have tried playing around with disconnecting different parts and I have tried leaving it overnight without the power or battery but I had no luck. Why would it suddenly work again the first time I try it and then magically break again?
Anyone got any ideas on what I can try?
  • 1 more comment
  • Lee Henderson Apr 12, 2008
    Ok, I have played around with it and I have made progress....ish!
    I now have power, the fan on the power supply is working and the main fan is working...ish. The main fan jutters and requires you to blow in it to get it started. Nothing else is responding.
    The power button is flashing rappidly and there are no other LEDs on.
  • Lee Henderson May 02, 2008
    OK, I have to say fixya....ish here.
    I have bought a new powerfully and a cook little doodad that checks if the power supply is working. I discovered that the old power supply was faulty and have replaced it. The fan now works properly not.... HOWEVER...
    The main power light around the button is still flashing. The disk drives are not working and when I plug in a monitor I hear an odd ticking but nothing else happens.
    Is this the motherboard? There are no beeps, same as before.
    Oh and I forgot to mention, I have tried plugging in a usb light, the light seems to flash compared to it on my working computer.
    This problem was the same before I got the new power supply.
    Genius:
  • 1,027 Answers
Sounds like intermittent power supply. Power supply not putting out required voltages.
Posted on Apr 05, 2008
SOURCE:
Key board not responding
Try this, it's the only suggestion I have with the tiny bit of information you gave me.
1. Turn off your computer.
2. Unplug keyboard.
3. Plug keyboard back in.
4. Turn on computer.
5. Try to be more specific when asking a question, you'll get help a lot sooner.
Apr 09, 2013 | Computers & Internet
Not turning on
try removing the battery and cleaning the contacts,,also check and make shure the charger is good
Jun 13, 2012 | LG KM555 Cell Phone
Hello my name is steven my dad gave me his hp pavilion a62n computer. I then plugged it in with my old computer wires and pressed the on button but after the lights came on and the fan started to spin...
I am assuming that it was working before he gave it to you.
Unplug the pc and open the case and touch the case to ground yourself before trying the next steps. Blow any dust out and away from all the fans, check that all the wires are plugged in tight, check the memory sticks and make sure they are pushed in. Try plugging it in with the cover open but do not touch anything inside with the power on and try it and make sure all the fans are turning. Let me know how this worked. Thanks for using FixYa
May 14, 2011 | HP Pavilion a622n (PC108A) PC Desktop
Emachine - no signal
This isnt a one step fix. Power off unit then while powering on tap F8 key to get menu with option to boot to safe mode. If this works could be a driver or malware issue which can sometimes cause windows to come up in safe mode but not normal mode. This is only a start not a solution.
Dec 06, 2017 | Acer AL2216WBD LCD Monitor
My Ipod touch 16G first generation. wont respond to my touch even to turn it off. its at the screen where it says slide to unlock and it wont respond to my touch.i havent dropped it and its in excellent...
1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
2. Open iTunes and sync the iPod as normal.
3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Oct 31, 2009 | Apple iPod touch
Emachine t3104 installed the VIA/S3G UniChrome Pro IGP Video Driver on my win xp then changed the color to 256 trying to resolve a java vm issue and gave me a message to change the resolution, but when the...
go to the safe mode by pressing f8 at startup.
in safe mode set the resolution to its default and restart. this will now run in normal mode.
dont forget to vote...
Sep 13, 2009 | E-Machines eMachines Desktop PC
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Installing a card reader
On my E210882 motherboard in an Emachine T2824, the card reader is plugged into J9F2 connector on the motherboard.
Aug 29, 2008 | Dell (E210882) Motherboard
E-Machines eMachines Desktop PC Logo
70 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
