We have a 62 inch t.v and it is out of focus i tryed to bring the red in order and the ccrosses wount match up
  • 8,617 Answers
You need new convergence ics. you can get them at the following link, they include installation instructions.you will need to change both ICs takes about an hour.
http://servicemanuals.vstore.ca/
Posted on Apr 05, 2008
Adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
Jul 02, 2012 | Husqvarna Garden
I replaced the crt coolant in my 62 inch phillips rear projection tv and the green and red are perfect but the blue is still out of focus when I go to the convergence the cross is perfect but the blue is...
hi,
try to change the crt base socket of blue gun and then try. i will suggest if you replace the base socket change all the three at the same time.
crt base
ok
Jan 20, 2011 | Televison & Video
I have a 2001 sony kp61hs30 that has always worked great. turned it on today, the blue and red do not match up. the flash focus button on the TV will not align the blue and red plus signs. Got any...
I have a 2002 sony KP61HS30 and the blue and red do not match up. I use the flash focus button and it does not align the red and blue plus sign. Have any suggestions?
Dec 11, 2010 | Sony KP-61HS30 TV
62" mitsubishi tv wavy picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jun 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Model number is 927030 the belt has no numbers on it it is 62 inch long
Take the belt to any mower shop and they can match it up, it is a common belt and is most likely a 61 inch belt on the inside they can give you a diagram to replace it with if you don't have it. it will cost about $30.00
Nov 20, 2009 | Ariens Garden
Manual Convergence won't work
You need an exact match or a factory authorized sub... Don't go to ebay or some outlet and assume it looks right just because someone with no experience tells you it might work, you're just asking for more headaches...
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Samsung PCL6215R 62" Rear Projection...
Picture is distorted w/ aline on top and bottom
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 30, 2009 | RCA HD65W140 65" Rear Projection...
Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
