Question about Dell Inspiron 6400 Notebook
Wireless is not working on Windows Server 2008
When trying to enable wireless network adapter and choosing to diagnose the problem I got following message:
The network adapter "Broadcom 802.11g Network Adapter" is experiencing driver or hardware related issues.
Which DELL driveres I should install to get it work correctly?
I already tried various dell driveres but same result :(
  • Anonymous Mar 28, 2014
    driver
  • 123 Answers
Janex,
try to enter bios set up,then use default settings..
Posted on Apr 08, 2008
SOURCE:
How to turn on wireless on Lenovo T61 laptop?
I checked the manufacturer's web-site:
http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=10&familyind=374625&machineind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FdownloadsDriversLandingPage.vm&validate=true
but did not find any device-driver for the wireless-adapter for your Operating System.
This might imply that the wireless-adapter is fully supported by the Operating System, i.e., no additional device-driver is needed.
Open the "Network Connections" window, and display all the currently-defined network-adapters -- the wireless adapter should be present. Select it, and right-mouse click on its icon, and choose "enable".
Apr 29, 2010 | Lenovo (40Y7026) Wireless Adapter
Windows 7
If your wireless connection is not working. click here to get solution.
Apr 23, 2010 | Microsoft Windows Vista Home Premium with...
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Netgear WG111 v2
go to manage wireless networks.. click on the network name choose manually configure.. set your wep key in there
Jan 06, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Installing on windows server 2008
Install the Wireless LAN Service feature under 'Features'
Nov 21, 2008 | D-Link WUA-2340 (ASKU55774) Wireless...
IT DOESNT WORK OUT
Sounds like your wireless is disabled.
If your using windows xp, check the following.
Go to your start menu
go to your control panel (might be under settings, might not.)
from control panel, if it says "Choose a Category" click switch to classic view.
open your Network Connections Icon.
If "Wireless Network Connection" is grayed out, right click it and choose, "Enable."
In Windows Vista
Go to the bottom right hand corner of your screen to the icons.
Right click on the double monitors (network connection)
Select Network and Sharing Center
Click on Open Network Connections
If "Wireless Network Connections:" is grayed out, right click it and choose, "Enable."
If it is enabled, and you already have wireless built in to your laptop, then it's possible the wrong wireless card is enabled. If this is the case, when you open your network connections, you will have two Wireless Network Connection Icons.
A Wireless Network Connection, and a Wireless Network Connection 2. Make sure 2 is enabled, and the first one without a number is disabled.
Let me know if this helps.
Mar 17, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Laptop cant connect wirelessly
Hey Charlie, If you re-installed your operating system you will need to get the wireless modem driver from your dell disk. For some reason they have not included the drivers in the windows software. If you can't find it then you can go on to the Dell site(obviously on another computer) and enter your service tag and get your drivers that way.
I hope this helps
Jan 17, 2008 | Computers & Internet
Dell Inspiron 6400 Notebook Logo
148 people viewed this question
Ekse
Clive
Clive
Alun Cox
